Author Topic: 4x Shock Replacement  (Read 3276 times)
Offline EMCD
« on: September 18, 2016 - 04:39:32 PM »
How many bananas is replacing all 4 shocks on a 1971 Cuda?
Re: 4x Shock Replacement
« Reply #1 on: September 18, 2016 - 09:16:58 PM »
 :clueless:
Offline EMCD
« Reply #2 on: September 18, 2016 - 09:31:51 PM »
So meant how hard is it to install them. Easy? Difficult? Any tips?
« Reply #3 on: September 18, 2016 - 10:01:40 PM »
Not hard 8 bolts/nuts , the upper rear is the hardest to get to often there is an access hole in the trunk floor
Offline EMCD
« Reply #4 on: September 18, 2016 - 10:13:58 PM »
Cool. I think I have the access holes in my original trunk pan. Are those the orange plugs on the hump in the trunk?
« Reply #5 on: September 19, 2016 - 12:27:24 AM »
yes
« Reply #6 on: September 19, 2016 - 01:23:27 AM »
Inspect the holes closely on fit of the bolt going thru on the upper rear shock mounts.
Quite often, these may be wallowed out because of age, air shocks, insufficient torque, or just parts that wore out.
The last thing you want is a hardened bolt eating away the mount area and getting worse.
I had this happen on mine and welded a washer as a re reinforcement to prevent it getting worse.
Offline EMCD
« Reply #7 on: September 19, 2016 - 08:00:19 AM »
That's a great idea! Thanks for the heads up.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: September 19, 2016 - 12:45:48 PM »
What access hole... jk 70.
« Reply #9 on: September 19, 2016 - 04:38:44 PM »
See the plug just to the left of the spare?
here you see both
for some reason they are not present on some....perhaps  some replacements did not come cut for them?
« Reply #10 on: September 19, 2016 - 04:42:03 PM »
1970 used different plugs on the TOP of that hump...not on the back side like other years.  It also wasn't JUST on 1970's.  There was some carryover into 71 I believe.
Offline EMCD
« Reply #11 on: September 19, 2016 - 05:13:48 PM »
perfect. I'll visegrip one end and ratchet the other and get them off. for the fronts, just remove the tires? can I do all of this with the car on the ground?
Offline got6pak
« Reply #12 on: September 19, 2016 - 11:48:20 PM »
It would be very difficult to do this with car on the ground. You don't need to take any tires off. Just jack up front which you really need to do anyway to allow room for the shock to drop out of the upper a-arm area. Put the front back on the ground and jack up the rear and repeat. Just did my fronts, doing rears in a couple days.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #13 on: September 20, 2016 - 02:20:05 PM »
Again what access hole.
Depends on the car.
« Reply #14 on: September 20, 2016 - 02:40:21 PM »
The only ones that I've seen without any hole have had the trunk floor replaced.
