Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
No spark....
« previous
next »
Print
Pages: [
1
Author
Topic: No spark.... (Read 1743 times)
HemiOrange70
Resident
No spark....
on:
September 18, 2016 - 06:26:32 PM »
340, Mopar orange box electronic ignition
Running fine then died
power to positive side coil and negative (took readings with meter)
tried new ballast resistor
tried new coil
no spark to distributor.
Block grounded
new starter relay and all connections appear to be tight
THey gave me this resistor not his one-does it matter?
any thoughts?
Logged
734406pk
Andy
Sr. Member
Re: No spark....
Reply #1 on:
September 18, 2016 - 07:17:12 PM »
do you have an ohm meter that you can use to check the resistance of the distributor magnetic pick up coil? Also are you checking for spark output at the ignition coil wire?
Logged
dodj
Sr. Resident
Re: No spark....
Reply #2 on:
September 18, 2016 - 08:44:55 PM »
Quote from: HemiOrange70 on September 18, 2016 - 06:26:32 PM
The above two statements I don't understand.
There should not be power on both sides of the coil... If you do there is an 'open' in your ignition wiring.
Not sure what you mean by 'no spark TO the distributor"? Coil secondary wire to ground? If so, probably caused by having power on both sides of coil?
Logged
1973 Challenger 440 4 spd
Chryco Psycho
Administrator
C-C.com Guru
Re: No spark....
Reply #3 on:
September 18, 2016 - 08:45:18 PM »
With the key on when you unplug the dist you should get a single spark .
check reluctor gap [.008]
either ballast will work
ECU may have quit , orange box are not made like they used to be , you may want to look at Revnator box
Logged
HemiOrange70
Resident
Re: No spark....
Reply #4 on:
September 19, 2016 - 12:00:55 AM »
I was told that if I run a meter wire from negative terminal battery to positive side coil and try to start I can measure reading, I did
then from positive battery to negative side coil and try to start and I did so that meant ECU was giving power to coil. I will look at ECU tomorrow-thanks
Logged
HemiOrange70
Resident
Re: No spark....
Reply #5 on:
September 20, 2016 - 09:13:08 PM »
ECU
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
No spark....
