Author Topic: Gas Gauge Issue  (Read 872 times)
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
Gas Gauge Issue
« on: September 20, 2016 - 12:43:19 PM »
Soo - My sending unit is brand new - and the terminals that connect to the tank are clean and good looking.
BUT
When I go around corners and get the tank sloshing, I get the gauge to register moementarily and then it slowly drops back to 0.   What the heck!?!   To me that says that the sending unit is bad and I just replaced it.
A LITTLE HELP PLEASE!   :feedback:
Want one?  Got one! ... finally
Re: Gas Gauge Issue
« Reply #1 on: September 20, 2016 - 12:46:26 PM »
Do you have the ground strap in place?
Offline anlauto
Re: Gas Gauge Issue
« Reply #2 on: September 20, 2016 - 12:51:24 PM »
They are known for being totally inaccurate. Try filling the gas tank up and see what it reads...most likely around 1/2....
Offline JayBee
Re: Gas Gauge Issue
« Reply #3 on: September 20, 2016 - 02:32:57 PM »
Maybe the float has a pinhole in it and it's got gas in it causing it to stay at the bottom. I had a float once with an unnoticeable hole in it.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline wantone
Re: Gas Gauge Issue
« Reply #4 on: September 20, 2016 - 03:52:56 PM »
I do have a ground strap but wouldn't know if it is installed correctly.
I have a brand new sending unit in the tank now and it STILL registers empty (like the last one did) whether it is or not.
Re: Gas Gauge Issue
« Reply #5 on: September 20, 2016 - 04:09:10 PM »
The ground strap just bridges the small piece of fuel hose between the main fuel line and the sending unit.  One end pushes onto the main fuel line...the other end just pushes onto the sending unit nipple.
To see if your gauge is faulty, you can ground the wire that plugs into the sending unit.  If the gauge needle swings to the full mark, the gauge is working.
Offline wantone
Re: Gas Gauge Issue
« Reply #6 on: September 20, 2016 - 04:16:01 PM »
Thanks Burdar!  I'll do that tonight.
