Author Topic: 5.7 question  (Read 1745 times)
Offline ripp6957
5.7 question
« on: September 23, 2016 - 09:42:44 AM »
I have an '04 5.7 Hemi that came from a truck. I want to put a 5 or 6 speed manual trans behind it in my wife's '70 Challenger. I have been told that 'any' modern factory trans will bolt up, is this true? I have found manual trans on eBay from '12-15 Challengers that are quite reasonable (from LKQ). Can I ASSUME that any trans from a car with a 5.7 will bolt up? Thanks in advance for any help. Mark the fireman
Re: 5.7 question
« Reply #1 on: September 23, 2016 - 10:03:58 AM »
Should be no problem , the only thing I can think of is the pilot brg in the back of the crank assuming the engine came out of a truck with an auto trans .
You will need the belhousing & clutch & the Viper 6 spd was an option with the 5.7 Hemi , the big issue is not the engine trans but the floor mods ro clear the much larger 6 spd & rear crossmember for the trans
Offline GoodysGotaCuda
Re: 5.7 question
« Reply #2 on: September 23, 2016 - 10:44:54 PM »
What are you trying to put it in?
Generally the Tremec TR6060 is the factory trans of choice but they do not come with a very ideal shifter location for an old Mopar. The passenger side starter adds a little more difficulty as well. As mentioned, you can kiss the tunnel and torsion bar crossmember goodbye, it takes pretty considerable modification.
I went with the T56 Magnum (Hot Rod friend TR6060) for my 5.7L Hemi.
« Last Edit: September 23, 2016 - 10:46:30 PM by GoodysGotaCuda »
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline ripp6957
Re: 5.7 question
« Reply #3 on: September 25, 2016 - 02:13:25 PM »
Thanks for the info!
Offline ec_co
Re: 5.7 question
« Reply #4 on: September 26, 2016 - 01:31:12 PM »
have you looked at Mcleod? they have a new 5spd manual for classic upgrades. If I remember correctly they built it small to fit most tunnels and the 1st production version went into a Cuda.
http://www.mcleodracing.com/index.php/driveline/muscle-car-5-transmission.html
http://www.mcleodracing.com/index.php/driveline/muscle-car-5-transmission/mcleod-racing-muscle-car-5-speed.html
'70 Barracuda /6 3spd BH23C0E
If at first you don't succeed, skydiving is not for you
