Author Topic: Intermittant no start  (Read 4350 times)
Offline mjb765
Re: Intermittant no start
« Reply #15 on: October 07, 2016 - 11:40:21 PM »
Do you have a tachometer connected to the coil?... A bad tach can kill the system...
Nope
Offline 73440
« Reply #17 on: October 09, 2016 - 03:41:49 PM »
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline mjb765
« Reply #18 on: October 09, 2016 - 05:50:21 PM »
http://www.4secondsflat.com/ecuwiringdiagram.html
One more wiring diagram
That's different from what I have. I have one blue wire on one side of the ballast and a blue wire and brown wire in the same connector on the other side. Those were both start and run on the same side of the ballast.
Offline 73440
« Reply #19 on: October 09, 2016 - 11:32:05 PM »
The FBO and mymopar diagram match, .
The photo is what I had to wire to get it to run with a dual ballast resistor, and a Rev-N-Nator.
Can you post a photo of how it is wired at ballast?
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline mjb765
« Reply #20 on: October 10, 2016 - 04:11:05 PM »
2 wire ballast...one side has 2 wires in one connector
Offline mjb765
« Reply #21 on: October 14, 2016 - 09:22:58 PM »
Replaced the ignition box and ordered and installed a wiring harness from Evanswiring.com.....starts every time now!!
« Last Edit: October 14, 2016 - 10:39:42 PM by mjb765 »
« Reply #22 on: October 14, 2016 - 10:36:38 PM »
 :2thumbs:
Offline mopar70maniac
« Reply #23 on: October 16, 2016 - 10:57:50 AM »
 check to see that the connector boot to the ecu is solid... back the screw out, then push the boot on tight before tightening the screw... that boot seems to be kinda hard to seat  :thumbsup:
Offline mjb765
« Reply #24 on: October 16, 2016 - 07:17:05 PM »
It's all working after the new Ignition box and harness.....but thanks!!
« Reply #25 on: October 16, 2016 - 08:32:23 PM »
I took an Exacto knife and made some carefully made slight shaves on the boot and it definitely fit more snug all the way in after doing that.
The rubber durometer is wrong and they are too thick.  FWIW
