Author Topic: Is this a stock 340 piston?  (Read 1174 times)
Offline Cudakiller70
« on: September 25, 2016 - 11:37:15 PM »
No markings I could see, also rotated past TDC it didn't quite make it to the top of block.
If so any guess what compression?  Heads are 3671587 if that's needed for compression guess :dunno:
The above is just my opinion
John Adams
Offline 1 Wild R/T
Re: Is this a stock 340 piston?
« Reply #1 on: September 26, 2016 - 12:19:02 AM »
72-73 340 not 68-71  First photo 72-73 piston... Second photo 68-71 piston...
« Reply #2 on: September 26, 2016 - 12:30:44 AM »
Thanks 1 Wild R/T
Mine looks more like the the first photo, judging by the flat width in the middle. :dunno:
Are most or all oversized Pistons stamped with size on top?
My block cast # 2780930 340-5, I think is a 1971 build.
John Adams
Offline 1 Wild R/T
« Reply #3 on: September 26, 2016 - 12:46:35 AM »
Most O/S pistons do have the O/S stamped in the top... The 68-71 piston will protrude above the deck, it has a chamfer around the edge so the piston doesn't contact any overhanging head gasket..  Back in the 90's Mancini was selling full sets of 72-73 340 std bore pistons for $50.00.... I bought a set with plans to use them in a 360...  But better options started coming available before I built it....
Offline blown motor
« Reply #4 on: September 26, 2016 - 09:07:46 AM »
What's the purpose of the notch on the side?
Offline 1 Wild R/T
« Reply #5 on: September 26, 2016 - 10:10:04 AM »
Identifies the front of the piston... The pin is offset to reduce thrust loading...
Offline 73_Cuda_4_Me
« Reply #6 on: September 26, 2016 - 12:10:09 PM »
The 72-73 pistons have a shorter 'compression height', and top of pistons only come up to about .085" below deck... the earlier ones are .010-.015 above the deck at TDC...
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline blown motor
« Reply #7 on: September 26, 2016 - 12:25:40 PM »
Thanks guys. I'm still learning.
« Reply #8 on: September 26, 2016 - 03:59:03 PM »
Ok, I think first picture is right for what I have stock 72-73 engine. My motor is not original , if I'm reading the stamped code on engine block in front on drivers side: HM 340 R 36440  134. Even though block casting is 1-14-71.
H= 1972
Checked with feeler gauge and straight edge cause that's all I got right now, but came up with .077 but that's not very scientificial. So it probably is .085.
John Adams
