Author Topic: How to decode stamped numbers on 340 block front drivers side?  (Read 5565 times)
Offline Cudakiller70
« on: September 26, 2016 - 04:06:00 PM »
I could only find a place for wedge motors decoding. http://www.moparts.org/Tech/Archive/motor/36.html
Trying to figure out what I have? This block is stamped HM 340 R 36440 134.
From googling around I'm pretty sure H = 1972 but not sure on the rest?
Has anyone done this or know where to look?
The above is just my opinion
John Adams
Offline RzeroB
  • In The Lou and looking for a new (old) ride
Re: How to decode stamped numbers on 340 block front drivers side?
« Reply #1 on: September 26, 2016 - 04:48:45 PM »
"HM 340 R 3644 0134" is the engine factory build ID.
You can break it down as follows:
Model year
Engine plant
Engine displacement
Special engine information
Build date in 10,000 day calendar format (why they came up with that monster I don't know)
Number of engines built that day
So in your case it would be:
H = 1972 model year
M = Mound Road engine plant
340 = 340 CI engine
R = regular fuel (vs a "P" for premium fuel which was stamped on the higher compression 68-71 340 engines)
3644 = 20 July 1971 assembly date in 10,000 day calendar format
0134 = 134th engine assembled at the Mound Road engine plant that day
There you go!  :cheers:
« Last Edit: September 26, 2016 - 04:51:07 PM by RzeroB »
Cheers!
Tom
St Louis, MO
Former owner of 16 classic Mopars. "It is better to have owned (Mopars) and lost then to have never owned at all" (apologies to Alfred Lord Tennyson)
« Reply #2 on: September 26, 2016 - 09:26:55 PM »
Model year
Engine plant
Engine displacement
H = 1972 model year
340 = 340 CI engine
Excellent Rzero! Appreciate your looking it up for me. That's the info I couldn't find and needed.  :cheers:
Thank you!
John Adams
Offline blown motor
« Reply #3 on: September 26, 2016 - 09:50:52 PM »
Where exactly are these numbers? All I have on the left side is the number 2780930-340-2 cast into the block. There are no letters.
« Reply #4 on: September 26, 2016 - 10:11:42 PM »
 On face of block, Drivers side front of block above green tape.
John Adams
Offline 7212Mopar
« Reply #5 on: September 26, 2016 - 11:45:37 PM »
Model year
Engine plant
Engine displacement
H = 1972 model year
340 = 340 CI engine
[/quote
HI RzeroB, mine started with CW. What will that translated to year and plant? Thanks
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Offline 7212Mopar
« Reply #6 on: September 27, 2016 - 12:08:17 AM »
Found it. It is a G and not C. 1971, Windsor
Offline blown motor
« Reply #7 on: September 27, 2016 - 08:49:28 AM »
Thanks Cudakiller. I never knew there was numbers there.
Mine read LM 340     400    187. It's very hard to read. Maybe if I sand the paint of it would show up better.
There is a digit between 400 and 187 but I can't make it out. Most likely 3, 5, 6, 8 or 0.
Does the L indicate 1973?
« Last Edit: September 27, 2016 - 10:00:48 AM by blown motor »
« Reply #8 on: September 27, 2016 - 11:47:54 AM »
For reading numbers I've had good luck doing one of two ways. First try rubbing your finger in a greasy oily spot, then rub across the numbers. 2nd way In that pick I used a single edged razor blade scrapped off the surface paint and the paint inside the stamped numbers/letters stayed making it easier to read.
 "L " I don't know  :dunno:
Wonder where RzeroB and 7212Mopar looked it up :dunno:
John Adams
Offline blown motor
« Reply #9 on: September 27, 2016 - 01:19:50 PM »
I did find a listing of date codes. According to that L is 75. But mine is a 340, no longer built in 75.  :clueless:
« Reply #10 on: September 27, 2016 - 02:41:35 PM »
 :poopoke:s :netherlands:
Stumbled on this, but not sure it helps.
http://moparcarparts.com/engineident
« Last Edit: September 27, 2016 - 02:44:02 PM by Cudakiller70 »
John Adams
Offline blown motor
« Reply #11 on: September 27, 2016 - 02:53:20 PM »
Ya that's where I found it.
« Reply #12 on: September 27, 2016 - 02:59:30 PM »
This might be better go to your year (73 ?)codes, I'm just scratching here cause I don't know.
http://www.lhmopars.com/vin66-74.htm
John Adams
