Author Topic: Caltracs or Pinion snubber  (Read 2012 times)
Offline crash340
« on: September 26, 2016 - 05:23:26 PM »
Guys, I have just fitted my D60 to my Cuda and need to control the axle wind up, its a truck diff so it has no bolt on snubber ability, right now there is about 2 3/4" clearance (drive shaft to floor just in front of the diff) as its a street car for the most, do I go caltrac or pinion snubber, new engine going in soon (600HP/727 manual), I will be hitting the drag strip from time to time as well.
Greg
73 Cuda
Brisbane, Australia
Offline Cudakiller70
Re: Caltracs or Pinion snubber
« Reply #1 on: September 26, 2016 - 09:48:22 PM »
I vote Caltracs  :2thumbs: more control and adjustable.
« Last Edit: September 26, 2016 - 10:02:59 PM by Cudakiller70 »
The above is just my opinion
John Adams
« Reply #2 on: September 26, 2016 - 10:23:59 PM »
Maybe wait and see how it behaves? Maybe just clamping the front section of the leaf springs will work for you.
Offline crash340
« Reply #3 on: September 26, 2016 - 10:34:40 PM »
Right now it has a stock 340 with a shift knitted trans, I took off with moderate acceleration and hit second and the yoke hit the floor! So I'm going to definitely require something, I'll try clamping the front segments but just have a feeling I'll need more with the bigger engine and sticky tires I feel,  :dunno:
Greg
73 Cuda
Brisbane, Australia
Offline 70chall440
« Reply #4 on: September 27, 2016 - 12:12:23 AM »
Greg - I can say with a lot of certainty that back in the day running a moderate 440 6 pack with no traction aids at all, I never had the yoke hit the floor... I think your springs are a bit weak... just saying. That said, the home made cal tracs that are posted on line (and on this site somewhere) would be where I would be headed especially considering the cost to get parts to where you are. You are an engineering guy, I am very sure you can devise something locally.
Current Mopar
Past Mopars
Offline crash340
« Reply #5 on: September 27, 2016 - 04:38:49 AM »
It's a bit of a combination of issues causing the driveshaft ( sorry not yoke) tagging the floor, the E body driveshaft reduces its diameter to I guess 2 3/4"? at the end to clear a floor brace, I've now got a full diameter 3.5" driveshaft and, I need to nose down the pinion angle by about a degree, I have 4 1/2 leaves in the spring pack so I do need to clamp them as well, I'm loathed to add a leaf but can if I have to as I don't want to raise the height of the back of the car if I can help it
Greg
73 Cuda
Brisbane, Australia
Offline 70chall440
« Reply #6 on: September 27, 2016 - 11:36:35 AM »
something like cal tracs or a pinion snubber that you bolt to the car..  :dunno:
Current Mopar
Past Mopars
Offline rUNCHARGER
« Reply #7 on: September 27, 2016 - 01:11:15 PM »
I was going to suggest a pinion snubber as it is cheaper but you have a truck diff. Yes, just order a set of Caltracks and be done with it. They are the best vendor I have dealt with in the past year, They shipped the parts the very day I ordered them. The parts are really high quality too. The same day I ordered the Caltracs I also ordered some subframe connectors from a well known supplier, both businesses charged my CC the same day and said they would ship the parts right away. Cal track did but the other company didn't and two months later when I finally received the very expensive subframe connectors I discovered they managed to powdercoat them the wrong colour too. It's cross border so it isn't worth shipping them back but I won't deal with that company ever again. I would deal with Cal trac with no hesitation whatsoever.
Sheldon
« Last Edit: September 27, 2016 - 01:15:35 PM by rUNCHARGER »
« Reply #8 on: September 27, 2016 - 01:28:14 PM »
They sell shims to put between the leaf spring and the perch to change the pinion angle.  I believe each shim is 2 degrees.  You could add a leaf and use a lowing block to get the back end where you want it.  I guess it depends on if you want it to look stockish or not.
Offline crash340
« Reply #9 on: September 27, 2016 - 04:24:44 PM »
Thanks guys, runcharger, which ones did you get the pivot plate that hangs down 3.5" or 5"?
Burdar, yes I am installing as set of 2 deg plates however i also need to raise the trans a little, using the crank/trans centerline, my drive shaft rises from there 2.7* and my pinion angle is a further 1* giving me a total of 3.7* nose down pinion angle compared to the crank. right now I have a slight vibration due to uni angle issue. so dropping the nose of the pinion 1* is preferred but you cant get them easily.
Greg
73 Cuda
Brisbane, Australia
« Reply #10 on: September 27, 2016 - 06:08:33 PM »
Seeing as you have the Ford Truck Dana couldn't you simply add a pinion snubber to the floor and let the rubber part hit on the rear end? Countless bolt on options available....
https://www.summitracing.com/int/search/brand/energy-suspension/product-line/energy-suspension-bump-stops?autoview=SKU&sortby=BestKeywordMatch&sortorder=Ascending
I'd have one just in case..... You don't want a spinning driveshaft hitting the floor.
Offline rUNCHARGER
« Reply #11 on: September 27, 2016 - 08:32:13 PM »
We used the short, street ones. Fast and easy install and they seem to do the job. The car had new XHD springs with clamps and the D-shift hit the floor no problem. I haven't tuned the bars yet as we still don't have slicks on it and street tires are hopeless.
Sheldon
Offline crash340
« Reply #12 on: September 27, 2016 - 09:00:43 PM »
If I could find a push in version I could as there is a 1/2" hole directly above the pinion I could use, I don't want to drill holes in the floor as I'm trying to keep mods to the body minimal due to matching numbers car
Greg
73 Cuda
Brisbane, Australia
