Author Topic: 70 Cuda door lock problems  (Read 1487 times)
Offline MR291
« on: September 27, 2016 - 01:23:00 AM »
I am having problems locking my car.  I can do it manually if I remove the door panels and move the lock link rod, but I can not do it with the key or with the locking lever inside the car.  Locks are new and turn freely.  I could use some suggestions.  Thanks.
Offline HP_Cuda
  • Mopar or No Car!
Re: 70 Cuda door lock problems
« Reply #1 on: September 27, 2016 - 01:44:50 AM »
Do the rods have the proper clips on them?
Offline Finoke
« Reply #2 on: September 27, 2016 - 07:12:15 AM »
Are the rods straight or bowed?
Sent from my SM-G920V using Tapatalk
Offline MR291
« Reply #3 on: September 27, 2016 - 09:55:35 AM »
Rods are fine, not bowed and proper clips.  There is just a resistance.  I can fully move the horizontal rod in the door back and forth by hand but only partially with the locking lever. The key from the door lock will unlock but not lock.  I have the same problem on both sides so I am wondering whether it is a vertical rod to the door locks issue.  Both locks have been replaced but I see nothing wrong and they move freely.
Offline MR291
« Reply #4 on: September 27, 2016 - 12:18:38 PM »
I was thinking along that line as well.  I will give it a try.  Thanks.
Offline MR291
« Reply #5 on: September 27, 2016 - 10:23:24 PM »
Okay it is not the locks.  When the the locking mechanism has been manually tripped in the door with a screwdriver the key lock and locking rod works.  The problem seems to be more an issue of the striker hitting the locking mechanism in the door.  I have adjusted the strikers on the pillar as much as I can but that does not trip the door lock mechanism as much as it needs to be to permit the locks to used.  Is there a way to adjust the door lock mechanism further.  I don't think that it can be moved, but there is an allen key adjustment.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: September 28, 2016 - 02:54:20 PM »
Ahh ok this might help.
Put your door striker where it needs to be. There is a hole in your door which an allen key can pass through right above the door lock mechanism. Loosen that up until it spins freely. Close your door to the desired level (basically mating up the door to the fender and rear quarter). Once you have it where you want it, tighten up the allen key and hopefully this will help with your problem.
Offline YellowThumper
  • I left the snow for this?
« Reply #7 on: September 30, 2016 - 05:12:02 PM »
If you have to move striker that much I would check to make sure your door hinges are not bad. This will cause door to sag and then tightly hang on the striker. Simply adjusting may be addressing the symptom not problem.
Offline MR291
« Reply #8 on: October 02, 2016 - 09:10:31 PM »
I believe it is in the adjustment of the doors as well, however any adjustments end up impacting the fenders which are going to need to be adjusted as well.  It is going to the body shop for some other adjustments so I will get them to have a look at this.  Thanks for the advice.
