Author Topic: Rear shock plates have different threads?  (Read 971 times)
Offline KillerBee
« on: September 28, 2016 - 04:51:11 PM »
I pulled the rear end and suspension from under the wife's Challenger.
I didn't pay much attention to the parts as I was planning to sandblast them and replace all the hardware.
I blasted the shock plates today and after looking closely at them I noticed the threaded studs the shock bolts attach to are different sizes. :clueless:
I don't imagine this is correct?
Any issues with just sourcing the correct nuts for each stud and use everything?
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: Rear shock plates have different threads?
« Reply #1 on: September 28, 2016 - 04:53:40 PM »
the one on the left has had a repair and a bolt welded to it. the one on the right is correct.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline anlauto
« Reply #2 on: September 28, 2016 - 04:55:43 PM »
Yea..what he said :iagree: Just use two different nuts unless you really care about the details :2cents:
« Reply #3 on: September 28, 2016 - 05:01:45 PM »
Parts stores sell a repair stud for those.  You have to torch off the original.  The new one bolts on.  I thought I saw that someone was making the original style again though.  You'd still have to torch the old one off and weld the replacement back on.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Last Edit: September 28, 2016 - 05:09:33 PM by mopardave »
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline KillerBee
« Reply #6 on: September 28, 2016 - 06:13:32 PM »
Thanks for the info guys, the previously repaired stud makes sense.
I took the shock plates to my local industrial fastener supply place and picked up 2 correct fitting grade 8 nuts for the shock plate studs and 2 new grade 8 bolts and nuts for mounting the top of the new shocks all for under $2.  :2thumbs:
« Last Edit: September 29, 2016 - 11:27:13 AM by KillerBee »
