Author Topic: Exhaust header collector flange warped  (Read 4232 times)
Offline msbaugh
« on: September 29, 2016 - 10:10:18 PM »
I'm trying to figure out how to seal a leak on both collectors.  These are on some older hooker super comps with 3" collectors.  The exhaust has a 3 hole flange on the backside that  mates to the header collector with a gasket in between. The flange toward the rear is warped so bad that it won't seal. The problem is that I can't replace the flange without cutting the exhaust pipe off.  I'm tempted to just weld it all together but this doesn't seem right.  Is my only option to cut the pipe, and weld on a new section with a new 3 bolt flange?
Offline GoodysGotaCuda
Re: Exhaust header collector flange warped
« Reply #1 on: September 29, 2016 - 10:14:29 PM »
Have any pictures?
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline msbaugh
« Reply #3 on: September 29, 2016 - 10:19:34 PM »
Ok this is the type of flange.  I guess I have to cut off the pipe, measure, and weld one of these back on.
http://www.jegs.com/i/Spectre/865/4641/10002/-1?CAWELAID=1710874329&CAGPSPN=pla&CAAGID=15769068431&CATCI=pla-193242953591&gclid=CKroqJKDts8CFQpnfgodYDAM4Q
« Reply #4 on: September 29, 2016 - 11:09:19 PM »
Are you just using the gasket or are you trying any sealant with it? I've heard the copper rtv works quite good(well?) on those flanges. I'd try it. It might get you by for awhile.
Offline rUNCHARGER
« Reply #5 on: September 29, 2016 - 11:19:31 PM »
They get bent by hitting the road or curbs. If you can easily pull the exhaust pipe out of the car you can straighten it by holding it against a flat surface and using a fairly large hammer to hammer it straight. I just hold them against the garage floor and 1 or 2 shots with a hammer gets them straight.
Sheldon
« Reply #6 on: September 30, 2016 - 12:18:02 AM »
Years ago I had headers on the 340.
The flange was bent as yours
Straightened them best I could,
Used orange high temp RTV
Glued 2 gaskets together with it and sealed after any spots.
Worked.
Offline AussieMark
« Reply #7 on: September 30, 2016 - 05:10:37 AM »
If all else fails you could take it to a local exhaust shop and have new flanges welded on they should be able to do it without removing the pipe.
Offline msbaugh
« Reply #8 on: September 30, 2016 - 10:09:10 AM »
So I'm thinking that they've been bent due to scraping the ground like mentioned.  My driveway is very steep and it scrapes pulling out.  I'll need to grind and shorten the new flange somewhat to prevent that from happening again.
The problem I'm having is that my whole exhaust is welded, there's nothing I can unbolt to remove the flange I'm going to either have to cut and clamp or weld new pipe.  The other issue is I welded an O2 bung right behind that flange and it doesn't want to slide over.  This is turning into a lot of work!!
« Last Edit: September 30, 2016 - 10:11:50 AM by msbaugh »
« Reply #9 on: September 30, 2016 - 10:44:16 AM »
They make a ball type header flange that doesn't hang so low.  If you are going to redo it anyway, I'd have one of those installed.  You'll have to have the old flange cut off(pipe and header) then the new connection welded back on.
Something like this...
https://www.summitracing.com/parts/flo-15938?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-flowmaster&gclid=CJyPi-mpt88CFQIpaQodGQcKHg
A good exhaust shop can make the same thing very easily.  I don't know if you have one near you or not.  Muffler shops seem to be a thing of the past since the OEM's went to stainless exhaust.
« Last Edit: September 30, 2016 - 10:58:59 AM by burdar »
« Reply #10 on: September 30, 2016 - 02:50:41 PM »
I have cut off the flange all together and used simple tabs and slipped on the pipe over the collector, no gaskets to blow out and helps with ground clearance.... :2cents:
Offline msbaugh
« Reply #11 on: September 30, 2016 - 11:11:19 PM »
I'm not sure I understand?
Offline Cudakiller70
« Reply #12 on: September 30, 2016 - 11:24:42 PM »
Do you have a picture?
Is it sealed?
The above is just my opinion
John Adams
