Author Topic: 1970 Challenger Standard Gauge Special  (Read 426 times)
Offline JoshsMuscleCarParts
  • Sponsor
« on: September 30, 2016 - 09:08:51 AM »
Josh's Muscle Car Parts 1970 Challenger Gauge Special
1970 Challenger Standard Amp Meter Gauge $113.48 With Code PHIL At Checkout.
Reproduction amp gauge for 1970 Dodge Challenger models with standard gauges. Manufactured from stamped die-cut steel and assembled using the best precision components to ensure accuracy and reliability. Each gauge follows the original detail using correct markings and colors.
http://www.musclecarparts.cc/shop/item.aspx/1970-challenger-standard-amp-meter-gauge/9920/
1970 Challenger Standard Fuel Gauge $113.48 With Code PHIL At Checkout.
Reproduction fuel gauge for 1970 Dodge Challenger models with standard gauges. Manufactured from stamped die-cut steel and assembled using the best precision components to ensure accuracy and reliability. Each gauge follows the original detail using correct markings and colors.
http://www.musclecarparts.cc/shop/item.aspx/1970-challenger-standard-fuel-gauge/9918/
1970 Challenger Standard Temperature Gauge $113.48 With Code PHIL At Checkout.
Reproduction temperature gauge for 1970 Dodge Challenger models with standard gauges. Manufactured from stamped die-cut steel and assembled using the best precision components to ensure accuracy and reliability. Each gauge follows the original detail using correct markings and colors.
http://www.musclecarparts.cc/shop/item.aspx/1970-challenger-standard-temperature-gauge/9919/
1970 Dodge Challenger Standard Clock Delete Plate $60.14 With Code PHIL At Checkout.
Reproduction clock delete plate for 1970 Challenger models with standard gauges. This injection molded plate includes the correct markings and takes the place of the dash clock on vehicles that did not include a dash clock assembly.
Mopar Authentic Restoration Part
http://www.musclecarparts.cc/shop/item.aspx/1970-dodge-challenger-standard-clock-delete-plate/9373/
Cuda Challenger Forum Members Save With Code PHIL At Checkout
