Author Topic: Adjusting hood  (Read 722 times)
Offline dave73chally
Adjusting hood
« on: October 01, 2016 - 04:15:40 PM »
Hood fit good before I removed it but forgot to mark how the hinges were set. The passenger side near the cowl is below the fender line. The hinge at the inner fender cannot move down any lower. How do I adjust it?
73 Challenger
Offline anlauto
Re: Adjusting hood
« Reply #1 on: October 01, 2016 - 04:23:44 PM »
Confused a bit...The hood is low at the cowl, and the hinge can't go lower ? :clueless: Wouldn't you want it hinge to go higher ?
« Last Edit: October 02, 2016 - 10:06:16 PM by anlauto »
Re: Adjusting hood
« Reply #2 on: October 02, 2016 - 09:52:23 PM »
twist the hinge if it sits low loosen the hinge bolts raise the rear of the hinge
Re: Adjusting hood
« Reply #3 on: October 03, 2016 - 09:26:43 AM »
Yup, that worked. Thanks  :thumbsup:
73 Challenger
