Author Topic: Anyone use Ratech reusable gasket for 8 3/4 center section?  (Read 718 times)
Offline KillerBee
« on: October 01, 2016 - 09:17:09 PM »
Getting ready to install an 8 3/4 center section in the housing.
I picked up a Ratech reusable gasket for the center section the last time I was at Summit Racing.
From what I understand no sealant is needed for these Ratech gaskets?
Anyone ever use one of these gaskets? Opinions? Experience?
Should I use any type of sealant?
Should I torque the bolts more or less?
Thanks.
Offline GoodysGotaCuda
Re: Anyone use Ratech reusable gasket for 8 3/4 center section?
« Reply #1 on: October 01, 2016 - 09:50:11 PM »
I've used Lube Locker in the past on Dana axles with good results. I didn't know there was an 8-3/4" reusable gasket option out there, I'll have to look into it.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline KillerBee
« Reply #2 on: October 01, 2016 - 10:03:36 PM »
Didn't get the best review at Summit's website.
https://www.summitracing.com/oh/parts/rat-5101r/reviews/
Trying to set the 8 3/4 rear up so I can change center sections more easily.
I'm starting with a 742 Sure Grip center section with 3.23 gear, if the wife isn't happy with it I have another 3.55 equipped center section ready to swap in.
I drilled and tapped a drain plug in the 8 3/4 housing and hopefully the reusable gasket lives up to it's name. :dunno:
« Last Edit: October 01, 2016 - 10:05:12 PM by KillerBee »
