Author Topic: Removing wire from bulkhead  (Read 1058 times)
Offline Fern
« on: October 02, 2016 - 08:05:05 AM »
I am trying to remove the blow motor wire from the engine side bulkhead connector.  I would like to take it out for use later. How does it come out without damaging the connector or wire ?
Re: Removing wire from bulkhead
« Reply #1 on: October 02, 2016 - 12:15:49 PM »
If you are trying to remove the blade part from the connector, push the wire into the connector to make sure it is in all the way, then with needle nose, squeeze the edges of the blade together, then pull on the wire, to pull it out.
Offline Fern
« Reply #2 on: October 02, 2016 - 01:17:51 PM »
Great,
Thanks
