E-body Parts
Author Topic: E-body Parts  (Read 731 times)
Offline Claudia
E-body Parts
« on: October 03, 2016 - 03:39:27 PM »
Need to move some of this stuff leftover from my build . . . all parts are in good condition and either used and cleaned, used - media blasted and primed or new.
70-71 Mopar Rallye Wheel Center Cap - 5
Mopar Front Shock Mounting Hardware Kit - 10
71 - 74 E-body / 71 - 73 B-body Steering Column Seal Retainer - 18
Mopar Fuel Line Hardware Kit - 15
          New, kit is for 3/8” supply line and ¼” return line
E-body Torsion Bar Set - 40
          774 bar and 775 bar
Mopar Electronic Ignition Module - 10
70-71 E-body Wiper Linkage Pivot - 40
Floor Heat Shield - 50
          Approximately 6’ x 4’
70-72 E-body 4 Speed Brake Pedal Pad - 5
70-74 E-body Standard Dash Light Bar - 50
E-body Rallye Dash Speedometer - 175
E-body Rallye Dash Tach - 175
E-body Rallye Dash Clock - 175
72 – 74 E-body Rallye Dash Lens - 125
70-74 Barracuda Weather Strip Channel Retainer Trim Set - 80
73-74 B-body Outside Mirror Gasket - 10
70 – 74 E-body Ignition Switch - 20
          Missing connector
70 – 74 E-body Key Buzzer Switch - 25
          Missing terminal ends
70 – 71 E-body Ignition Key Lock - 20
70 – 74 E-body Turn Signal Switch - 25
          Missing connector
Mopar A, B and E-body Upper Steering Column Bearing and Insulator - 25
Mopar Window Crank Handles - 20
Mopar Late 60’s Interior Door Handles - 10
          Have two LH handles
Mopar Dome Light Assembly - 40
Holley Blue Electric Fuel Pump - 85
Mopar Trunk Lid Latch Striker - 20
B / E-body Trunk Lid Latch Striker - 20
Mopar Trunk Lid Latch - 20
70-74 Barracuda License Plate Light Lens - 10
70-74 Plymouth Barracuda Fuel Tank Filler Neck Tube - 35
71 Barracuda Chrome Grill Taillight Bezel Set - 50
