Author Topic: Electronic Distributor conversion no spark  (Read 4505 times)
Re: Electronic Distributor conversion no spark
« Reply #15 on: October 07, 2016 - 08:04:59 AM »
Question, if the tach wire doesn't go to the negative side of the coil as per the service manual where do I connect it so my Rallye Tach will work?
The tach killing the ignition is not an uncommon thing with these cars...
Offline usraptr
« Reply #16 on: December 03, 2016 - 11:44:45 PM »
Dodj, any solution to the problem?
(Edited 8-1-17)
« Reply #17 on: December 04, 2016 - 09:04:57 AM »
1/ Check the grey wire for ground on it's way from the coil thru the firewall to the tach. It may have rubbed off the insulation somewhere
2/ If the wiring checks out, repair or replace the tach.
RTE sells replacement guts.
http://rt-eng.com/rte/index.php/Main_Page
Offline usraptr
« Reply #18 on: December 05, 2016 - 11:29:48 AM »
Thanks Dodji.  I'll check the grey wire out.
(Edited 8-1-17)
