Author Topic: Durango 5.7, good donor?  (Read 4675 times)
Offline b5cuda
« on: October 05, 2016 - 10:15:21 AM »
Hey gang,
I'm looking to do a 5.7 swap into my '73 cuda and got a lead on a bargain-priced 5.7 out of a wrecked Durango.  Is a 2005 'truck motor' a good candidate in terms of fit, accessory location, oil pan, etc. or should I be looking for a car motor?  Thanks,
Bill
Offline twoterpilot
Re: Durango 5.7, good donor?
« Reply #1 on: October 05, 2016 - 05:08:38 PM »
I used an 2004 5.7 from a durango. the oil pan will need to be changed to a Miloden pan, everything else on the front will fit with out any problem.
Offline b5cuda
« Reply #2 on: October 05, 2016 - 05:58:48 PM »
Sounds good, thanks for the reply!  Can you post a pic of engine bay?  I'm wondering how accessories are oriented.
Offline twoterpilot
« Reply #3 on: October 05, 2016 - 08:23:25 PM »
I'm out of town for work until the 24th so I can't post any picks till I get home. if you look for the thread titled sheblbydogs 72 he has some photos of a challenger with the 5.7 truck engine in it.
Offline 3D
« Reply #4 on: October 05, 2016 - 09:05:52 PM »
Use the truck motor, the car block has the accessories mounted to low on the pass side and may hit the frame rail.
Offline GoodysGotaCuda
« Reply #5 on: October 05, 2016 - 09:28:32 PM »
The car timing cover mounts the accessories low, the blocks are the same. There are no clearance issues with the car timing cover and accessories in an e-body.
I bought a truck motor and would not suggest it. By the time you buy a car timing cover, accessories, intake, fuel rail, etc...you might as well just went with a car engine to begin with. The oil pan won't do you much good unless you are planning on an aftermarket k-member.
Mine:
« Last Edit: October 05, 2016 - 09:31:15 PM by GoodysGotaCuda »
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline b5cuda
« Reply #6 on: October 06, 2016 - 10:26:32 AM »
Thanks for info, good to know that both car and truck donors are options.  There are pics of both truck and car 5.7's in e-bodies on Shelby Dogg's 72 cuda page (http://www.cuda-challenger.com/cc/index.php?topic=33441.75 - great info there!), think I prefer the looks of the car-style arrangement.
Offline 3D
« Reply #7 on: October 06, 2016 - 06:51:01 PM »
Why didn't you use the truck stuff??? The truck motor works fine, its not necessary to switch.
and yes the oil pan wont work for either motor with a stock "K"
Mine:
Offline 3D
« Reply #8 on: October 06, 2016 - 06:52:53 PM »
« Reply #9 on: October 06, 2016 - 08:19:07 PM »
Aesthetics.
1976 Dodge Warlock
Offline 73restomod
« Reply #10 on: October 07, 2016 - 03:02:16 AM »
Truck motors made more power 05-08 hehe. In all seriousness, the truck intake kills the car intake, even on modded motors. 6.1 car is only good for a max ported, cammed, stroker, or supercharged builds.
« Last Edit: October 07, 2016 - 03:09:21 AM by 73restomod »
Offline 70chall440
« Reply #11 on: October 07, 2016 - 12:14:52 PM »
Current Mopar
Past Mopars
« Reply #12 on: October 07, 2016 - 07:51:05 PM »
I'd still have to look at it, at some point. This build is for road racing/autocross intent, a couple of horsepower won't make or break my lap times.
I would have to do some research before getting in a swirl over a blanket claim that the truck intake has more area under the curve for this specific cam/header application anyway. FWIW I am using a 5.7L car intake.
« Last Edit: October 08, 2016 - 06:25:11 AM by GoodysGotaCuda »
1976 Dodge Warlock
Offline 73restomod
« Reply #13 on: October 08, 2016 - 04:32:27 PM »
Well stock for stock the trucks from 05-08 5 more horsepower. and the 09 ups make 20 to 25 more out of the box, not sure if the car 5.7s have caught up yet. Cam specs are the same car to truck. There was some comparisons done where the car 5.7 and truck 5.7 it consists of cam upgrade and long tubes, and the truck intake trounced it handily for midrange torque and a few hp up top. Not trolling, you can look at the numbers advertised by dodge and see for yourself.
« Last Edit: October 09, 2016 - 03:59:55 PM by 73restomod »
