Hello, my step father and myself are working a nice 70 Challenger R/T clone.
The car was a 318 ci car and had 4 drum brakes from the factory ; front ones were swapped for disk brakes, but now the disks need to be changed as they show signs of worn.
Owner ordered new drilled front discs for 70-72 Challenger from Summit, new wheel bearings and new pads but we are unable to mount all the stuff because of the diameter of spindles which are 35 mm (1,37 inch) thick (measured just behind the internal bearings, see picture).
The spindles look thicker than 70-71 stock spindles. Do you think they come from a specified aftermarket drum to disc brakes conversion kit ? Or maybe from 73-74 Challenger ? If you have any info about that, it would be great !
Thank you for helping
