Author Topic: 71 cuda auto shifter T handle  (Read 3400 times)
Offline culp71
« on: October 06, 2016 - 02:50:17 PM »
tried to installed the T "slap stick" handle in 71 cuda, but the button does not spring back out once pressed in, with handle removed everything works. it is a new "reproduction" handle. is there anything to check, adjust, or grease? to allow button to slide in and out smoothly?
Offline culp71
Re: 71 cuda auto shifter T handle
« Reply #1 on: October 11, 2016 - 11:05:48 AM »
removed handle, all functions correctly, as soon as t handle is slid down onto shaft something binds and prevents button from moving, any thoughts?
Offline 1 Wild R/T
« Reply #2 on: October 11, 2016 - 11:19:26 AM »
Try pulling some lube on the area where the button & rod contact each other...
Offline culp71
« Reply #3 on: October 11, 2016 - 11:53:00 AM »
I did try that yesterday evening...no change, but I looked really closely and noticed when I slide the handle down just before it reaches the set screw hole, you can watch the button get pushed back,(towards back of car) causing the button itself to no longer sits in the center of the handle hole opening...
« Reply #4 on: October 11, 2016 - 12:13:08 PM »
Post a photo of the shifter shaft and of the T-handle itself.   You might have to take apart the T-handle and inspect.
There where two different styles of T-handle used in 71.  I assume they use the same shifter though.  Just the plastic slide in the gear selector was different.
Offline culp71
« Reply #5 on: October 11, 2016 - 12:38:53 PM »
will do, thank you.
Offline AARTA340
« Reply #6 on: October 11, 2016 - 01:35:07 PM »
I had similar issues when replacing mine. Not sure what I actually did, but remember when I first installed the new one, it was doing as you described. Took it off and looked at it and it seemed it should work, but it still was not cooperating. If memory is correct, I had to use a small screwdriver to position the mechanism inside the shifter handle so it would fit on the metal shifter and align with the small pin that the button pushes down. And yes, lube the shifter.
Offline culp71
« Reply #7 on: October 14, 2016 - 08:49:07 AM »
alright here a bunch of pic I took last night hope they will help to figure out
why once T handle is installed, then button pushed in, will stay in no matter what position shifter is moved to, once I remove the set screw in handle it springs up and about 1/4" and functions fine.
« Last Edit: October 14, 2016 - 10:00:49 AM by culp71 »
Offline culp71
« Reply #8 on: October 20, 2016 - 07:56:44 AM »
still no resolve on this shifter issue.
I am contemplating ordering another T handle from a different source as last one...
« Reply #9 on: October 20, 2016 - 09:08:35 AM »
It would be nice if you were able to test an original handle.  Is there anyone around you that would have one you could test?  Have you tried disassembling the handle you have?
What are the chances that your attaching screw is too long?  If it's too long, it could touch the center rod...keeping it from moving freely.
« Last Edit: October 20, 2016 - 09:10:43 AM by burdar »
Offline aarcuda33
« Reply #10 on: October 20, 2016 - 11:43:06 AM »
You have a 72 and later  T handle not  a 71 T handle but I don't know if that is the cause of your issue . I don't think that would  create your problem they should interchange
« Reply #11 on: October 20, 2016 - 01:25:15 PM »
I'm not sure how long they used the first style T handle but I think some 71's got the updated design.
Offline anlauto
« Reply #12 on: October 20, 2016 - 04:13:25 PM »
Weird...That's exactly what I was going to say, but I thought nobody could over look that.... :banghead:
Offline culp71
« Reply #13 on: October 31, 2016 - 02:43:56 PM »
not sure still what's going on here, unable to figure out how to take current handle apart with out damage so I ordered  another new 71 style T handle, hoping it functions correctly.
Offline anlauto
« Reply #14 on: October 31, 2016 - 03:49:12 PM »
Did you check the length of the screw ?
