Author Topic: 71' cuda antenna hole location ?  (Read 560 times)
Offline 76orangewagon
« on: October 07, 2016 - 08:26:03 PM »
I have a correct (I think) antenna for my 1971 Cuda and the antenna wont work properly so I looked at at backside of the fender and saw a circle in the bracing that was bigger to accommodate the bezel than where my antenna hole was drilled....so did someone drill this in the wrong location ?????
Offline anlauto
Re: 71' cuda antenna hole location ?
« Reply #1 on: October 07, 2016 - 10:09:04 PM »
YES...The antenna is in the wrong location...Your fender was changed at some point  :2cents:
« Reply #2 on: October 07, 2016 - 10:20:00 PM »
Damn it....more stuff to correct. Thanks again Alan.
« Last Edit: October 07, 2016 - 10:21:53 PM by 76orangewagon »
