Author Topic: transmission conversion (crank)  (Read 1748 times)
Offline Dgoode87
« on: October 09, 2016 - 12:31:34 PM »
So i has been saving my nickels and dimes for a tremec conversion, but i recently heard that my crank might not work for a manual transmission (something to do with the hole on the back of the crank). I have a 75 or 76 360 LA in the car. I've tried to find anything about this on the net but have come up empty. does anyone here know anything about this?
Thanks in advanced
David
Offline 1 Wild R/T
Re: transmission conversion (crank)
« Reply #1 on: October 09, 2016 - 01:08:33 PM »
The original style pilot bearing went in the bored & finished pocket in the back of the crank... If the crank wasn't destined for a M/T application it often didn't get machined fully...
Theres a newer design bearing that works well to retrofit an unfinished crank, instead of going into the deep pocket it presses into the shallow pocket that centers the torque convertor....     Pt number Mopar P4876056AA Pilot Bearing
« Last Edit: October 09, 2016 - 01:12:55 PM by 1 Wild R/T »
Offline Dgoode87
« Reply #2 on: October 10, 2016 - 06:50:05 AM »
so if i get this new part i will be able to swap to a manual
Offline 1 Wild R/T
« Reply #3 on: October 10, 2016 - 10:17:52 AM »
yup
Offline jhaag
« Reply #4 on: October 10, 2016 - 10:29:38 PM »
What about the depth of the pilot hole in the crank? Make sure it has been drilled deep enough to accept the tip of the input shaft. You don't want it to bottom out before the trans reaches the bellhousing.  :2cents:
love 70 Challengers
Offline 1 Wild R/T
« Reply #5 on: October 10, 2016 - 11:32:28 PM »
If the pilot hole isn't deep enough the pilot area of the input shaft can be shortened since it's now supported closer to the clutch disc...
Offline Rolling_Thunder
  • only 2 things get my attention, gas and perfume
« Reply #6 on: October 11, 2016 - 11:51:04 AM »
most newer transmissions (Tremec) don't have a long snout like the old 833s...   I;ve seen plenty of 833s with the snout circumsized with no ill effects...
2013 Dodge Challenger R/T - 5.7L / 6-speed
1973 Dodge Challenger Rallye - 340 / Auto
1968 Dodge Charger - 6.1L / 6-speed
1964 Dodge Polara - 440 8-71 / 4-speed
Offline Dgoode87
« Reply #7 on: October 11, 2016 - 05:13:51 PM »
all good stuff guys thanks
Offline Mopar Mitch
« Reply #8 on: October 12, 2016 - 03:34:58 PM »
Interesting info... as I, too, have had thoughts of possibly changing from my 727 to a manual (maybe the Passon 4-spd aluminum OD unit.. their 5-spd is taking forever to get done.. and that is  long-shot possibility)... or maybe just install the SS 4L60 4-spd automatic.
Offline bigblue73
« Reply #9 on: November 07, 2016 - 08:36:30 AM »
The roller pilot bearing for the Tremec's is different from the mopar unit.  The mopar unit is for the 833's only.  The O.D. of the input shafts for the Ford based Tremec TKO 5 speed and the Chevy based T56 Magnum are different and have there own bearing.  If you need help with the Tremec stuff let me know.  I have the roller pilot pilot bearing for both for $50.00 shipped.
