so one step forward two back, prepped column for install with all restored parts, gaskets, grease, new shoes, clip spring, seal, etc.
slide column through floor/connected to PS box with no issues, lined up master notch and tapped in pin. went inside car, lifted column temporally into approx. spot, slide down floor/firewall gasket, larger yin-yang plate, then smaller plate finger started all fasteners all looked great.
Then slide on main column bracket and its about 1 inch from the stud that stick down from the dash/column bracket. no matter how I shift or move stuff it will not reach, furthermore I can see the indentation on the bracket and it looks like the original bolts that where there where centered in the slots, which mean it about 2 inch's off....
what am I doing wrong??
pictures would help.
