Author Topic: My Son's 2007 Mustang needs help  (Read 4443 times)
Re: My Son's 2007 Mustang needs help
« Reply #15 on: October 12, 2016 - 02:16:08 PM »
The response to this inquiry seems reasonable... I also read that clearing the computer, not just the codes, may be necessary
http://www.transmissionrepaircostguide.com/topic/2010-mustang-automatic-dealer-says-i-need-new-auto-transmission/
Offline EbodyMod
  • Will it ever be finished????
« Reply #16 on: October 12, 2016 - 02:40:15 PM »
Yes, once the solenoid is replaced the  computer has to be cleared or the codes will not go away. a standard handheld will not do it.   Did you have any of the offending codes?
:wavingflag:  Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
Offline daveh
« Reply #17 on: October 12, 2016 - 03:00:46 PM »
The more and more I look into this the more it looks like the Solenoid.  Apparently there is a Shift Solenoid kit that comes with a couple of solenoids a trans filter and gasket.  How do I identify which trans the V6 has and does anyone know of such a kit?  Thanks
Offline EbodyMod
« Reply #18 on: October 12, 2016 - 03:07:23 PM »
Offline daveh
« Reply #19 on: October 12, 2016 - 03:41:54 PM »
Offline roadman5312
« Reply #20 on: October 12, 2016 - 04:58:20 PM »
Man that's an expensive part.  Easy enough to do but not sure I want to risk it if it isn't the issue?  Thoughts...
https://www.amazon.com/Ford-9L2Z-7G391-Trans-Control-Solenoid/dp/B00AQZARIE/ref=as_li_ss_tl?ie=UTF8&redirect=true&ref_=as_li_tl&ref_=nav_ya_signin&&linkCode=sl1&tag=fordt-20&linkId=f700ddf7e94dd24f26fe8b5bc701a803
               My buddy @ the dealer said that's probably it, but of course only taking it to a dealer is the only way to know for sure   :stomp:   :banghead:
Offline 1 Wild R/T
« Reply #21 on: October 12, 2016 - 07:23:19 PM »
Drop the pan, if it's clean the chances are the solenoid pack will fix it... Debris... Well probably not...
Offline EbodyMod
« Reply #22 on: October 13, 2016 - 10:18:30 AM »
