Author Topic: Rear drum to disc brake convert, what do you guys recommend?  (Read 3241 times)
Offline cuda2420
« on: October 12, 2016 - 03:07:46 AM »
Looking for a basic drum to disc brake conversion kit (with park brake) for my 1970 Plymouth Cuda with a Chrysler 8.75 rear end.
What do you guys recommend?
Offline crash340
Re: Rear drum to disc brake convert, what do you guys recommend?
« Reply #1 on: October 12, 2016 - 03:49:52 AM »
DR DIFF
Greg
73 Cuda
Brisbane, Australia
Offline soundcontrol
« Reply #2 on: October 12, 2016 - 05:21:28 AM »
I got this kit from Wilwood:
https://www.summitracing.com/int/parts/wil-140-7144-dr
and Green bearings from Dr Diff. And a new 489 case with 3.55.
Still in boxes though.
« Last Edit: October 12, 2016 - 05:56:26 AM by soundcontrol »
/ Ken
topic=108917.new#new
Offline djw383
« Reply #3 on: October 12, 2016 - 06:21:23 AM »
Dr Diff, I used his kit and it is nice stuff. He uses oem Ford Cobra calipers, and from my research oem is better than race ones as they are less likely to leak when sitting. If you are using stock front discs his 10 inch kit works well to keep things in balance. Also, I believe his kit is the only one you can use the stock rear sway bar with. Never mind great customer service...tell him what you have, and your goals and he will put you in the right direction.
Sent from my HTC6525LVW using Tapatalk
« Reply #4 on: October 12, 2016 - 08:04:46 AM »
Another vote for DrDiff. Mine are working great  6 years now.
Offline cuda2420
« Reply #5 on: October 12, 2016 - 08:42:54 AM »
Thanks a lot for the advice, I will contact doc. diff
Offline shawge
  • Zoiks!!
« Reply #6 on: October 12, 2016 - 01:14:28 PM »
Dr Diff.
Here's my install. On a S60 w/ Torino bearings, works w/ FF rear sway bar
http://www.cuda-challenger.com/cc/index.php?topic=110341.msg1087697#msg1087697
- Jerry
Offline 7212Mopar
« Reply #7 on: October 12, 2016 - 03:46:39 PM »
But the smaller Dr. Diff 10.7 rear kit had been out of stock and has been for quite some time. Unless your go with the 11.7 kit that requires the 13" front kit.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
« Reply #8 on: October 12, 2016 - 03:51:13 PM »
Dr Diff.
So a Wilwood kit will not work with a FF sway bar? I think I got the wrong info then.
/ Ken
Offline shawge
  • Zoiks!!
« Reply #9 on: October 12, 2016 - 05:10:16 PM »
 :dunno: Not sure about the Wilwood kit
- Jerry
Offline Surfmichaels
« Reply #10 on: October 12, 2016 - 05:25:04 PM »
I emailed cass back in July on the small rear brake kit , he said at the time it'll be around 3 months till they are back in stock. So maybe soon...
« Reply #11 on: October 12, 2016 - 05:56:12 PM »
It will work, just looked a Cuda, it has same Wilwoods as me and a stock type swaybar, its not even close to the brakes.
/ Ken
Offline Mopar Mitch
« Reply #12 on: October 13, 2016 - 01:57:32 PM »
I intend to buy the Dr Diff 10.75 rear disc setup... as soon as it avlble from Cass/Dr Diff.
Offline cuda2420
« Reply #13 on: October 13, 2016 - 02:41:06 PM »
e mailed with Cass at he said the 10,7" kit will be back in stock within the next couple of weeks
Do anyone have pictures of this kit mounted on a car?
« Reply #14 on: October 13, 2016 - 04:55:17 PM »
See the link posted above in shawge 's post
