Author Topic: Air fuel meter. How do you get the cable in to the cabin  (Read 2619 times)
Offline MopSquad
« on: October 13, 2016 - 01:35:45 PM »
I have an LM-1 wideband. It has the O2 to sensor screwed into the the exhaust before the H pipe. The sensor runs a cable to the handheld control unit. How does everyone get the cable to the handheld inside the car? '70 Cuda convertible.
TIA
Offline 70chall440
Re: Air fuel meter. How do you get the cable in to the cabin
« Reply #1 on: October 13, 2016 - 01:40:32 PM »
Going to have to make a hole. I have a WB A/F gauge in my Cuda and had to make a hole in the trans tunnel up at the front. The ends are fairly large, so your hole and subsequent cover needs to cover it. There are a number of aftermarket type covers/grommets so you are not left with a gapping hole. I usually make a 2 piece type cover so that when in place, only the cable is coming out.
Current Mopar
Past Mopars
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: October 13, 2016 - 01:46:33 PM »
The LM-1 model is usually used for temporary readings and not a permanent affixed AFR guages.
You can make a temp hole and then cover it up or if only temporary figure out how to bring it into the car. As I think I remember the cables are fairly long?
Offline Mopar Mitch
« Reply #3 on: October 13, 2016 - 02:02:42 PM »
I have thoughts of also getting an AF gauge... can't the wiring simply be passed through the shifter hole in the trans tunnel (automatic may be different than manual)?
Offline MopSquad
« Reply #4 on: October 13, 2016 - 02:19:46 PM »
I'd hate to make a hole.  I'm not sure how I could snake it through the shifter hole. Perhaps removing the boot temporarily.  The smallest aperture would be to drop the O2 sensor through its hole. The connectors are larger than the O2 sensor
Offline rUNCHARGER
« Reply #5 on: October 13, 2016 - 02:35:15 PM »
No need to cut any holes. Make a slice in the body plug that is closest to your o2 sensor and run the cable through the body plug. Then just run the cable under the carpet near the sill plate and kick panel and then up to the dash frame. I ran it all under the dashframe, the wiring to the gauge was trickier but I just ran it through the ashtray and up to the gauge which I secured with one of the screws that attach the dash lights. All easy to remove that way with no evidence.
Sheldon
Offline MopSquad
« Reply #6 on: October 13, 2016 - 02:40:37 PM »
Sheldon
Thx.  I'll look for the plug.  It's just a temporary thing to get the carbs dialed in. No permanent gauge.
Offline 1 Wild R/T
« Reply #7 on: October 13, 2016 - 05:14:33 PM »
I ran the cable through the oval shaped plug for the clutch rod since I have an automatic... You could also use the plug that was for manual pump type windshield washers...
Offline MopSquad
« Reply #8 on: October 13, 2016 - 05:22:45 PM »
Thanks for the schematic.  More options. Have to see how long the cable is.
« Last Edit: October 13, 2016 - 05:24:28 PM by MopSquad »
« Reply #9 on: October 13, 2016 - 05:34:17 PM »
That's what I did if I remember right.
Offline ec_co
« Reply #10 on: October 13, 2016 - 05:53:35 PM »
there are also wireless/bluetooth options now
'70 Barracuda /6 3spd BH23C0E
If at first you don't succeed, skydiving is not for you
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: October 13, 2016 - 06:02:42 PM »
Hot dang!!!
Offline MopSquad
« Reply #12 on: October 13, 2016 - 06:30:49 PM »
Double hot dang!
http://www.jegs.com/i/AEM/017/30-2320/10002/-1
I think it still has mucho cables though.  Just can be monitored on your Iphone etc...
« Last Edit: October 13, 2016 - 06:32:29 PM by MopSquad »
Offline YO7_A66
« Reply #13 on: October 13, 2016 - 09:30:35 PM »
 I fed both of my harnesses up thru the bottom of the car up thru the auto shifter boot. Then under the carpet/console to the firewall.
Offline mopar jack
« Reply #14 on: October 13, 2016 - 11:40:09 PM »
Ran my cables up through the floor on the pass side through large body plug under the carpet and ran it up to the firewall and behind the heater box. Then I routed it to the glove box where I can plug in my scanner. You don't even notice the cables under the carpet. I leave the cables in the car and pull the O2s when I am done tunning.
