Trunk mount battery, best side, left or right?
Author Topic: Trunk mount battery, best side, left or right?  (Read 8566 times)
Offline Tazinhawaii
Re: Trunk mount battery, best side, left or right?
« Reply #15 on: October 20, 2016 - 06:29:12 PM »
Funny, I'm in the middle of doing this right now on my Cuda on the cheap...  Done it many times on other cars.  I simply took the battery tray from the engine compartment and mounted it to the trunk floor on the right side.  Then used the stock hold downs (had to make an extension for one of them).  Connected the negative cable to the mounting bolts (after cleaning up the paint).  Going to Lowes tomorrow who has 1, 2, and 4 gage stranded wire in stock and sell by the foot.  MUCH less expensive than the kits or summit/jegs.  I'm thinking I'm going to run the positive cable from the battery under the car and up the tunnel.  Then connect directly to the starter.  I hear people talking about running the ignition wires as well.  Actually, you don't have to.  Simply run a wire from the starter terminal post with the battery cable up to the solenoid where the old + cable connected.  This provides power to the car and solenoid.  Works every time.  I also run the alternator output wire to that same battery terminal on the starter.  Electrically it's the same as stock.
Derrick
1971 Cuda 440 six pack.  Original TX9 Black on Black.  Located in southern NH.
Offline roadman5312
« Reply #16 on: October 20, 2016 - 07:07:16 PM »
Derrick
                                                :2thumbs:
Offline 70chall440
« Reply #17 on: October 20, 2016 - 09:31:01 PM »
                                                :2thumbs:
 :2thumbs:
Current Mopar
Past Mopars
Offline crackedback
« Reply #18 on: October 20, 2016 - 10:21:41 PM »
I would not run a cable in the tunnel area of the car.  It's a recipe for bad things to happen if you lose a driveshaft.
Also, check the wire that Lowes has in stock, you want multi-strand of thin wire in the bundle, not home style thick gauge wire.
Offline 70chall440
« Reply #19 on: October 20, 2016 - 10:47:13 PM »
Here is the tray I made for my Cuda. I put the battery disconnect on it along with the fuel pump relay.
Current Mopar
Past Mopars
Offline marc70challenger
« Reply #20 on: October 22, 2016 - 10:45:19 PM »
From my understanding welders wire works as well - is that correct?
1970 Challenger 340 Performance Package
1965 Barracuda - "The Pumpkin"  http://www.cuda-challenger.com/cc/index.php?topic=116471.0
Offline 70chall440
« Reply #21 on: October 22, 2016 - 11:56:13 PM »
Correct, I have used welding cable for years.
Current Mopar
Past Mopars
« Reply #22 on: October 23, 2016 - 06:43:05 AM »
 :iagree:  that's what I have used also.  :2thumbs:
« Reply #23 on: October 23, 2016 - 08:27:42 PM »
I always use welding cable & route through the car inside  .
 Side note fatory Gm routed the + cable through the driveshaft tunnel in corvettes for many years , just not the best way IMO
Offline 1 Wild R/T
« Reply #24 on: October 24, 2016 - 01:34:11 AM »
Ford ran the brake line in the driveshaft tunnel.. But I wouldn't....
« Reply #25 on: October 30, 2016 - 07:37:37 PM »
Cool.   :2thumbs:   Starting the wiring now.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #26 on: November 06, 2016 - 10:40:32 AM »
Any update?  And anyone know the size eyelet you need for the starter post? Maybe 5/16"?
« Last Edit: November 06, 2016 - 10:55:26 AM by dfrazz »
« Reply #27 on: November 06, 2016 - 08:49:57 PM »
I'm still in the trunk.    :smilielol:
Someone should know though.
« Reply #28 on: November 06, 2016 - 10:13:30 PM »
My Battery is mounted on the Right Hand Side of the Trunk, also with Welding Cable.
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« Reply #29 on: January 18, 2017 - 03:23:30 PM »
What size cable do you guys use on the Welding Cable?
AWG   Diameter (Inch)
4/0 AWG   0.4600
3/0 AWG   0.4096
2/0 AWG   0.3648
1/0 AWG   0.3249
1 AWG   0.2893
2 AWG   0.2580
3 AWG   0.2290
4 AWG   0.2040
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
