Author Topic: stiff rear springs  (Read 931 times)
Offline chargerdon
stiff rear springs
« on: October 13, 2016 - 07:09:11 PM »
What should a "stock" rear leaf spring look like on a 74 Challenger.    I.e How many leafs??  My springs appear to have a total of 5 leafs.
They must be super heavy duty as as it rides a little high and If I try to bounce the rear I can barely deflect the rear end more than 1 inch!!  There is plenty of clearance between the bounce stop rubber and the stopper, so thats not the problem.
Re: stiff rear springs
« Reply #1 on: October 14, 2016 - 10:16:35 AM »
Low level cars have 4 leaf packs. The performance cars came with 5 on the left and and 5 with 2 half leaves on the right. If someone put competition springs under yours, it could have even more. If someone modified your original set, you could have a single, thicker leaf in there as well.
Yes, some leaf packs are fairly stiff. However, some shocks are similarly stiff. To differentiate, you can disconnect your shocks and see if you can now move the suspension. If yes, you have a shock problem. If no, then your spring pack is the issue.
You do want a fair amount of clearance between the housing and the bumpers so you don't bottom out, but you don't want them too close either.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2 on: October 14, 2016 - 10:37:39 AM »
What kind of shocks do you have?  Air shocks for example can raise/lower your car and effect the stiffness as well.
Offline 1 Wild R/T
« Reply #3 on: October 14, 2016 - 08:19:08 PM »
Also KYB's tend to be quite harsh...
