Author Topic: Adding a inertia fuel pump shut off switch  (Read 1734 times)
« on: October 16, 2016 - 09:28:02 AM »
Just replacing my electric fuel pump with my spare and I got to thinking ( again, I never did it before)  about adding a inertia fuel pump safety switch.
What have others done?  Is there any problems with them being to sensitive as to vibrations, acceleration, etc....
 Where do you suggest mounting it? ( trunk?)
I was looking at this one....
http://www.ebay.ca/itm/111749555643?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Offline 1 Wild R/T
Re: Adding a inertia fuel pump shut off switch
« Reply #1 on: October 16, 2016 - 10:09:58 AM »
I wouldn't say that switch is sensitive to vibrations at all, but having worked at Ford dealerships through the 80's & 90's I did have to reset a few when cars would come in on a hook... Generally when someone had absolutely slammed the trunk shut & occasionally when someone slammed the left rear door....  There are two contacts which also happen to be fairly strong magnets, a large ball bearing & a medium strength spring pushes against the ball trying to separate it from the magnets.... It takes a pretty solid shot to open the circuit...
If your running a relay it's best to wire the switch on the control side so it passes less current but in some applications Ford did put it in the main circuit....
Offline GoodysGotaCuda
« Reply #2 on: October 16, 2016 - 10:14:54 AM »
I have two of those Ford switches in my garage, I plan on using one in my Barracuda. It takes a pretty good whack to get it to kill the fuel pump, I don't expect that you will have any issues in this application.
In my Ford Ranger, I used to smack the passenger kick panel when parking in a sketchy area, it would trip that inertia switch and kill the truck. Not a bad form of theft deterrent.  :biggrin:
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #3 on: October 16, 2016 - 12:30:26 PM »
Thanks for the input!  I bought the one in the e-bay link. I'll wire it to the control side like you suggested ( I am running a relay) :2thumbs:
« Last Edit: October 16, 2016 - 01:09:47 PM by brads70 »
Offline shawge
  • Zoiks!!
« Reply #4 on: October 19, 2016 - 02:09:25 PM »
Where are you going to mount it? I like Goody's idea of the kick panel but there is not a lot of room there.
- Jerry
« Reply #5 on: October 19, 2016 - 03:17:22 PM »
Planning on mounting it in the trunk. The relay for the fuel pump is back there along with the battery....
Offline crash340
« Reply #6 on: October 19, 2016 - 07:25:59 PM »
How do you reset it if it functions on a hard stop or knock to enable a restart?
Greg
73 Cuda
Brisbane, Australia
Offline roadman5312
« Reply #7 on: October 19, 2016 - 07:51:24 PM »
    push reset button.
« Reply #8 on: October 19, 2016 - 09:29:58 PM »
Offline crash340
« Reply #9 on: October 19, 2016 - 09:35:55 PM »
Just needed confirmation, that's great! Might invest in one myself
Greg
73 Cuda
Brisbane, Australia
Offline EbodyMod
  • Will it ever be finished????
« Reply #10 on: October 19, 2016 - 10:10:36 PM »
Not to hijack the thread but i was going to install one as well as a rollover vent shutoff. Anyone using those?
:wavingflag:  Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
