Author Topic: Kickdown  (Read 1333 times)
Offline Cuda_451
Kickdown
« on: October 16, 2016 - 08:37:18 PM »
I'm having problem with my Kickdown linkage not staying connected. It keeps popping off. Any ideas on how to fix it?
1970 Plymouth Barracuda
1995 Dodge RAM 1500 SLT
2006 Ford Mustang V6 Supercharged
Re: Kickdown
« Reply #1 on: October 16, 2016 - 10:30:54 PM »
Where is ti popping off ? Carb trans , in between ?
Offline Cuda_451
Re: Kickdown
« Reply #2 on: October 16, 2016 - 10:35:41 PM »
The trans
Offline Cuda_451
Re: Kickdown
« Reply #3 on: October 17, 2016 - 07:40:51 PM »
Re: Kickdown
« Reply #4 on: October 17, 2016 - 08:37:03 PM »
Can we assume you have the correct arm and have tried tightening the bolt up?  Could you post a picture?  :wave:
Re: Kickdown
« Reply #5 on: October 17, 2016 - 09:36:21 PM »
the link should have a washer & cottor pin to hold it into the arm
Offline 1 Wild R/T
Re: Kickdown
« Reply #6 on: October 18, 2016 - 11:12:53 AM »
Your parts should look similar to this....  There are a few different design clips holding everything together, I suspect one is damaged or missing...
Offline Cuda_451
Re: Kickdown
« Reply #7 on: October 18, 2016 - 11:28:20 AM »
Mine is more of a solid single piece rod
Offline 1 Wild R/T
Re: Kickdown
« Reply #8 on: October 18, 2016 - 11:51:17 AM »
So you have a 71 or newer design.... Still needs to be a clip...
Re: Kickdown
« Reply #9 on: October 18, 2016 - 12:07:19 PM »
I found this picture online.  The upper clips are the style you need for the main kickdown rod.
Offline Cuda_451
Re: Kickdown
« Reply #10 on: October 18, 2016 - 01:22:37 PM »
Okay, I bought a new clip. Now how do I properly adjust it?
Re: Kickdown
« Reply #11 on: October 18, 2016 - 09:11:17 PM »
with the throttle wide open the rod should be back as far as it will go without limiting throttle travel . if it shifts too hard or too late you can shorten the rod a little
