:banghead:I have got my new 419 stroker engine on the run stand. running a MSD 6al2 box, 8388 rtr dist, mad atomic efi. 26" 4 core radiator from champion, dual electric fans. 180 deg thermostat. engine start nice and runs with about 12 degrees initial timing 37 all in at 2700 but runs about 10 min and starts to overheat. I shut it down around 110 to avoid any damage. Is it possible I have a timing issue causing her to get to hot? I am going to try a lower thermostat today, possibly order larger fans. but I really don't want to kill it already. Any suggestions???
71 340 block 4.080 bore
eagle forged balanced crank 4" stroke
eagle h-beam rods
icon forged pistons, moly rings
clevite adv bearings
melling high volume oil pump
milodon 9qt deep pan
indy t/a head cnc ported bowl,runners, chambers/ gasket matched. heads milled for 65CC chamber
2.055/1.625 manley valves
shaft mounted 1.5 roller rockers
lunati voodoo hyd roller dur 294/302, dur @.50 243/251, lift .590/.600, lsa/icl 110/106
crane cam double roller timing chain set straight up
fluidamper balancer
eddy rpm air gap
8388 msd RTR dist no vacuum adv, 15deg bushing, light silver and light blue spring
