Author Topic: Pitman Arm Torque Question  (Read 1201 times)
Offline daveh
« on: October 20, 2016 - 10:48:50 PM »
Hey guys,
I'm installing my new Pitman Arm on my new Firm Feel box.  The only socket I have big enough to fit is from my 3/4" socket set which I don't have a 3/4" torque wrench.
I have a little anti-seize on the threads and I'm not sure how much to tighten the nut?  My 1/2" torque wrench only goes to 150lbs even if I could use it.  Do I just tighten it until I can't tighten it any longer and call it a day?  Thanks for your help.
Re: Pitman Arm Torque Question
« Reply #1 on: October 20, 2016 - 11:47:18 PM »
I found a spec of 175 , most 1/2 torque wrenches go higher than 150 & you will need an adapter
Offline Katfish
  • 70 Challenger
« Reply #2 on: October 21, 2016 - 07:52:57 AM »
Add a 2-3' pipe on your 1/2 rachet for leverage and pull!
It'll be good.
Offline EbodyMod
  • Will it ever be finished????
« Reply #3 on: October 21, 2016 - 08:47:41 AM »
It'll be good.
:wavingflag:  Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
Offline daveh
« Reply #4 on: October 21, 2016 - 08:50:04 AM »
That what I figured I would do.  Thanks for the confirmation.
Offline YellowThumper
  • I left the snow for this?
« Reply #5 on: October 21, 2016 - 10:00:06 PM »
They make 3/4 to 1/2 drive adapters.  Buy it torque to your wrenches max spec. Now you know at lease the minimum you have. Then whip out the big ol extension for more.
