Author Topic: 5.7L Hemi + T56 Magnum 'Cuda Build  (Read 50536 times)
Offline EB3-GranCoupe
  • BP23 U0B
Re: in primer!
« Reply #30 on: November 19, 2016 - 09:03:46 AM »
Looking fantastic Goody!!  (I'm gonna miss the flat hood tho!)   :cheers:
« Last Edit: November 19, 2016 - 09:05:18 AM by EB3-GranCoupe »
Offline djw383
Re: in primer!
« Reply #31 on: November 20, 2016 - 08:56:21 AM »
It is so nice when you can put parts on the car, and leave them on the car.....
Sent from my HTC6525LVW using Tapatalk
Offline GoodysGotaCuda
Re: in primer!
« Reply #32 on: November 20, 2016 - 12:01:09 PM »
I'm really looking forward to my parts pile getting smaller!
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 1 Wild R/T
Re: in primer!
« Reply #33 on: November 20, 2016 - 12:23:51 PM »
Boy do I ever get that.... Looking Great Mike!!! :cheers:
Offline Rolling_Thunder
  • only 2 things get my attention, gas and perfume
Re: in primer!
« Reply #34 on: November 20, 2016 - 03:27:11 PM »
BC / CC ?    Top Banana I assume?    PPG ???    I am looking at painting my challenger soon and looking at opinions on paints. :cheers:
2013 Dodge Challenger R/T - 5.7L / 6-speed
1973 Dodge Challenger Rallye - 340 / Auto
1968 Dodge Charger - 6.1L / 6-speed
1964 Dodge Polara - 440 8-71 / 4-speed
Re: in primer!
« Reply #35 on: November 20, 2016 - 06:29:40 PM »
Looks good Mike.
I heard that's a hard color to get right the correct shade.
Re: in primer!
« Reply #36 on: November 20, 2016 - 07:09:15 PM »
BB/CC Lemon Twist/Top Banana, it's PPGs entry-level "Shop Line". Not the best stuff, but I do plan on driving the wheels off of the car regardless.
Looks good Mike.
Painter said the same, my car had been painted quite a few times (all FY1) and so I am not sure which is right. The color he showed me on the card looked right to me.
1976 Dodge Warlock
Offline spoiledrottenauto
  • Newbie
Re: in primer!
« Reply #37 on: November 25, 2016 - 08:34:07 AM »
Goody how are you? You still in central Florida? Im in west Orlando. We met a few times at Garlits. I'm doing a 5.7 for my 72 satellite and i have questions for you. Could you call me sometime at 32129946twofive?
Sent from my SM-N910T using Tapatalk
Re: in primer!
« Reply #38 on: November 25, 2016 - 09:32:48 AM »
Hi there, actually I am out in the Dallas-Fort Worth area now.  :wave:
1976 Dodge Warlock
Offline YellowThumper
  • I left the snow for this?
Re: in primer!
« Reply #39 on: November 25, 2016 - 03:22:02 PM »
Looking great. Partial to the color as well.
Btw time to rename this thread...
Re: 5.7L Hemi + T56 Magnum 'Cuda Build
« Reply #40 on: November 27, 2016 - 10:39:55 PM »
So it looks like this thread has turned into a build thread, so here is my latest update!
Stripes are here from Phoenix Graphix, the same 1972 stripe it came with. Body shop says they will need it this coming week, so we may see the car home soon!!
Black Friday was a great opportunity to load up on stuff I need, over the last two weeks the following has been ordered/procured:
  • Dr. Diff Rear axle shafts w/green bearings
  • Phoenix Graphix 1972 Barracuda stripe kit
  • Vintage Air non-Factory A/C evaporator kit
  • Wilwood 12.88" 6-piston front brake kit (red calipers, drilled/slotted)
  • Wilwood 12.2" 4-piston rear brake kit w/parking brake (red calipers, drilled/slotted)
  • Wilwood 7/8" Bore master cylinder, EDP coated with combination and adjustable proportioning valve
  • Associated Wilwood brake lines and e-brake cables
  • Hotchkis E-body front upper control arms
  • Hotchkis E-body Front/Rear sway bar kit
  • Hotchkis Lower Control Arm pivot/pin kit
  • Hotchkis Tie Rod kit
  • Hotchkis strut rod kit
  • Speedhut custom gauge set [Tach w/speedo, Oil psi, water temp, AFR and fuel level]
  • EFISource MegaSquirt MS3 Gold Box (ECU) for 3rd gen Hemi w/harness
  • Coleman 1.5:1 steering quickener
1976 Dodge Warlock
« Reply #41 on: November 27, 2016 - 10:45:49 PM »
With minor tweaks, this is the gauge set I ordered. The voltmeter was swapped out for an AFR gauge.
Vintage Air!
Steering quickener
1976 Dodge Warlock
Offline Cudakiller70
« Reply #42 on: November 27, 2016 - 11:02:06 PM »
Like the yellow gauges nice touch with body color. Also like the AFR idea.
Have never seen or heard of a steering quickener before. Curious how it installs.
The above is just my opinion
John Adams
« Reply #43 on: November 28, 2016 - 06:57:44 AM »
Hotchkis has one in their challenger, it takes a bit of work and several connections to get done.
1976 Dodge Warlock
« Reply #44 on: November 28, 2016 - 07:59:40 PM »
1976 Dodge Warlock
