Author Topic: removing stuck fastener - useful YouTube reference  (Read 1521 times)
Offline dakota
« on: October 22, 2016 - 06:30:31 AM »
I had a carb stud stuck in my intake manifold that I wanted to remove, but it was proving to be very stubborn.   I came across the YouTube video below that turned out to be helpful in keeping me from snapping the stud.  Even with the addition of the wax, my attempt to remove the stud by "double nutting" didn't work because I was using general duty 5/16" nuts.   The threads on the nuts stripped when snugging them together.   I didn't want to waste the time tracking down a set of Grade 8 nuts that would've worked better, so I used a pipe wrench instead to remove the stud.
It was a small moment of joy when the stud started to turn out rather than twist.
https://www.youtube.com/watch?v=7qqMXXGgFQg
« Last Edit: October 22, 2016 - 06:43:56 AM by dakota »
Offline soundcontrol
Re: removing stuck fastener - useful YouTube reference
« Reply #1 on: October 22, 2016 - 07:10:13 AM »
Thats amazing, did not know wax would work like that, had a bolt stuck in my 340 head, tried everything with no luck, had to leave it to a machine shop that charged me 150 to fix it. Thanks for sharing.
/ Ken
topic=108917.new#new
« Reply #2 on: October 22, 2016 - 09:11:49 AM »
An old friend that I got my business from taught me that trick when I asked him why he had birthday candles in his tool box?  Works really good!  :2thumbs:
Offline 60K T/A
« Reply #3 on: October 24, 2016 - 06:19:29 PM »
WAX. Who would have thunk it?
T/A, Survivor,
M37B1 Sold
W350
It took about 35 years for the "politicians" to RUIN this country just to line their pockets
Offline roadman5312
« Reply #4 on: October 24, 2016 - 07:33:16 PM »
                Heat always works for me, never used wax.
Offline cudabob496
« Reply #5 on: October 27, 2016 - 06:37:54 PM »
Ya, wax is an oil, and penetrates a little, just like WD-40.
But I think the main reason the things are coming out is
 the hot base metal expands, and that relaxes the grip on the stud.
After heating, I would ice cube the stud, and it should come out easier.
also, touching the stud with the wax cools the stud as well.
so I think temp differentials between the two metal components is more of a factor.
« Last Edit: October 27, 2016 - 06:39:38 PM by cudabob496 »
2011 Kawasaki Z1000
« Reply #6 on: October 27, 2016 - 06:50:41 PM »
I use freeze spray to find problems in electronics, circuitboards and such, that would probably work on the bolt also.
/ Ken
Offline roadman5312
« Reply #7 on: October 27, 2016 - 07:08:17 PM »
                              Just heat (torch ) always works for me.
Offline cudabob496
« Reply #8 on: October 27, 2016 - 07:21:29 PM »
yep, though scientifically, water/ice has the best heat removal capability of any compound.
something to do with latent heat of vaporization.
2011 Kawasaki Z1000
Offline twalker
« Reply #9 on: October 27, 2016 - 08:18:22 PM »
Cool.
Offline dakota
« Reply #10 on: October 27, 2016 - 08:54:21 PM »
This picture shows the end of the carb stud that was stuck in the manifold.   Except for the top of the lower threaded area, the threads were pretty clean once I got it out.   I'm not sure how well it can be seen in the picture but there's actually a little shine to the threads that is either a really thin film of wax that wicked in or some of the WD-40 from previous removal attempts.   Either way, this was a bugger to get loose and I'm glad it came out without snapping.
Offline cudabob496
« Reply #11 on: October 27, 2016 - 09:27:18 PM »
I use anti-seize quite a bit
2011 Kawasaki Z1000
« Reply #12 on: October 28, 2016 - 06:22:04 AM »
Gonna remove a brass T coupler from my compressor, its stuck, looks like its glued in there also, I see some kind of hard, epoxy like material just above the threads, is that any common sealer they use on compressor tanks? Gonna try heat to see if it dissolves. Very bad if I break it, then I have to drill it out and maybe ruin the threads and get metal debris in the tank.
/ Ken
Offline wagenbob
« Reply #13 on: November 01, 2016 - 02:22:04 PM »
It's probably just pipe dope, the liquid alternative to teflon tape. You should be able to heat it, tighten just a hair, and then back it out.
-- Bobby
