Author Topic: Can a torque converter kill the motor when shifting into D.  (Read 1296 times)
Offline roadman5312
« on: October 24, 2016 - 04:48:57 PM »
          It's a 73 Duster, 318, mild cam, Edelbrock intake 4 barrell. Stock 727 with stock converter. If the idle is set @ 900 @ operating temp and you put it in gear it dies. In order to keep it running the idle has to be @ 1300/1400 rpm's.  This guy is being told it's the converter. Transmission operates good, shifts fine.   :clueless:
Offline 734406pk
  • Andy
Re: Can a torque converter kill the motor when shifting into D.
« Reply #1 on: October 24, 2016 - 08:00:21 PM »
If the converter was so worn that it would stall the engine, it would make one heck of a racket IMO. The symptoms sound like a lean condition, vacuum leak etc. Power brake booster ruptured may be?
Offline jhaag
« Reply #2 on: October 24, 2016 - 09:13:15 PM »
quick and simple answer is yes. However if the cars drives and shifts normally, it sounds more like a tuning issue. You need to provide more info. Did this just start? Was the car running and driving normally before this happened? Was anything changed that could have affected the way the car runs? etc. etc.
love 70 Challengers
« Reply #3 on: October 25, 2016 - 08:00:02 AM »
 Very unlikely , more tuning or dist issues
Offline Strawdawg
    • Vortex Buicks
« Reply #4 on: October 27, 2016 - 10:41:12 AM »
A bigger cam can cause an engine to die when you drop it into gear on a stock converter...particularly if the engine is cold.
But, a mild cam that allows the engine to make 12-14 in/hg at 900 rpm idle should work fine with a stock converter.  In that case, it sounds like a tuning/engine problem as mentioned.
Offline 73_Cuda_4_Me
« Reply #5 on: October 27, 2016 - 11:07:53 AM »
If you are running a stock distributor, you might be running into the same mechanical curve problem I had on my 340... with a mild cam, it needs a little higher idle speed and 15-18 deg advance at idle, and mechanical curve starts coming in around 900, adding 5-10 degrees advance, and when you drop it into drive, it loads the engine just enough to cause mechanical advance to drop off, and engine stalls.
I built an advance limiter plate with slots shortened on inside edge, so the advance springs were a little tighter at idle, yet limited total advance to 36 degrees all in. My advance curve now starts at 1300 instead of 900. With an auto, you should get about 200-250 RPM droop when put in D...
If you watch timing light and adjust idle speed from 600 to 900, if timing shifts from your initial, then you have same issue as I did... my timing was floating around 5 degrees and wouldn't stay the same on different days... kept fussing with it until I put in the limiter plate, then was rock solid...
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
