Need to move these . . . contact me if you would like to do a package deal on everything and I can work with you on pricing.
Open to trades for needed E-body or 440 parts.
71 Barracuda Headlight Bucket Mounting Bracket LH – 85
70-71 Mopar Rallye Wheel Center Cap - 5
Mopar Front Shock Mounting Hardware Kit – 10
70 - 74 E-body Inner Fender Splash Shield w / Clips RH - 10
71 - 74 E-body / 71 - 73 B-body Steering Column Seal Retainer - 18
Mopar Fuel Line Hardware Kit - 15
New, kit is for 3/8” supply line and ¼” return line
E-body Torsion Bar Set - 40
774 bar and 775 bar
Mopar Electronic Ignition Module - 10
70-71 E-body Wiper Linkage Pivot – 50
70-74 E-body Front Windshield Lower Trim Molding - 100
70-74 E-body Front Windshield Driver Side Upper Corner Trim Molding - 50
70-74 E-body Front Windshield Driver Side Lower Corner Trim Molding - 30
Floor Heat Shield - 50
Approximately 6’ x 4’
70-72 E-body 4 Speed Brake Pedal Pad - 5
70-74 E-body Standard Dash Light Bar - 50
E-body Rallye Dash Speedometer - 175
E-body Rallye Dash Tach - 175
E-body Rallye Dash Clock - 175
72 – 74 E-body Rallye Dash Lens - 125
70-74 Barracuda Weather Strip Channel Retainer Trim Set - 80
73-74 B-body Outside Mirror Gasket - 10
70 – 74 E-body Ignition Switch - 20
Missing connector
70 – 74 E-body Key Buzzer Switch - 25
Missing terminal ends
70 – 71 E-body Ignition Key Lock - 25
70 – 74 E-body Turn Signal Switch - 25
Missing connector
Mopar A, B and E-body Upper Steering Column Bearing and Insulator - 25
Mopar Late 60’s Interior Door Handles – 10 for both
Have two LH handles
Mopar Dome Light Assembly - 50
Holley Blue Electric Fuel Pump - 100
Mopar Trunk Lid Latch Striker - 20
B / E-body Trunk Lid Latch Striker - 25
Mopar Trunk Lid Latch - 25
70-74 Barracuda License Plate Light Lens – 10 each
70-74 Plymouth Barracuda Fuel Tank Filler Neck Tube - 40
71 Barracuda Chrome Grill Taillight Bezel Set- 50
