My 74 Challenger with a big cam (mopar performance 508) 360 is easy to start when cold. Fires quickly will stumble and then takes a couple of restarts before it starts running smooth. I have the timing set at about 20 degrees BTDC where it seems to run the best. At that setting, it does have i little amount of kickback in turning it over.
Then If i drive the car long enough to be fully warmed up and turn it off and try to restart, it only turns a half rev and then bogs... Multiple key hits all does the same thing... half turn and then stops... Let it sit for four to five minutes and hit the key and it turns over easily and starts.
It has in it a high torque mini starter.
Is my problem battery?? Voltage regulator not fully charging battery?? I note that the amp gauge is in the neutral position before shutting it off, the mini starter, or simply too much advance??
