Author Topic: New Intake, Car Hesitates  (Read 735 times)
Offline nsmall
« on: October 27, 2016 - 03:09:17 AM »
I had a Weiand 8007 intake on my mild built 340.  Now I have the Edelbrock Air Gap RPM intake.  My car hesitates for the first second when I floor it.  Any suggestions on how to correct this?  Once the hesitation stops, the car runs great and really moves.  Is this common for the Air Gap intake?  I have carter carb and stock fuel pump.  Didnt hesitate with the Weiand intake.
Thanks!!!
Offline cudabob496
Re: New Intake, Car Hesitates
« Reply #1 on: October 27, 2016 - 03:11:52 AM »
hmmm, if not doing before, wonder if vacuum leak?
2011 Kawasaki Z1000
« Reply #2 on: October 27, 2016 - 07:35:25 AM »
Generally you need more duel with the acclerator pump so you need to install a larger squirter
Offline jhaag
« Reply #3 on: October 27, 2016 - 11:58:50 AM »
Agree with CP. Anytime you change your engine combination you will need to retune. Try increasing your accelerator pump shot. You may also find that manifold may like a different timing setting or spark advance curve.
love 70 Challengers
