Author Topic: 73 cuda side markers ideas  (Read 4656 times)
Offline 70chall440
Re: 73 cuda side markers ideas
« Reply #15 on: October 29, 2016 - 01:09:25 AM »
I knew somebody here had done it....That looks great ! :2thumbs:
Thanks, Mopar should have done it from the beginning, those lights were/are always the first thing to get broken plus it looks so much better set in.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #16 on: October 29, 2016 - 01:12:24 AM »
Any worry about moisture collecting back in there?  Did you drill any drain holes?
Not really, however I suppose you could. In my case it is a pretty tight fit and the car will be garaged all the time. That said, it would be possible to put some.
Current Mopar
Past Mopars
Offline 72bluNblu
« Reply #17 on: October 29, 2016 - 02:49:52 PM »
I'm using '68 sidemarkers on my Duster. The front fenders are '71's, but the rear quarters are '74 so I have to do the same thing. The hole in the fender/quarter is a little too big, so some welding is still required, but all you need to do is weld in a small patch to make the opening small enough for the '68 bezel to cover it. They do stick out still, they aren't flush, but they weren't flush on the '68 cars either. And with the bezel it doesn't look strange like the 72+ sidemarkers that look stuck on.
Offline rhamson
« Reply #18 on: October 31, 2016 - 10:12:45 AM »
Very Cool. :cooldancing:
Offline Markp
« Reply #19 on: November 19, 2016 - 05:30:24 PM »
I want to do the same to my 74 the rears are steel but my front fenders are fiberglass. How hard would it be to do this to fiberglass?
1974 Cuda Pro Street Project ???hp
2000 Camaro SS 383 Stroker 550hp
2016 Challenger Hellcat 707hp
Offline 72bluNblu
« Reply #20 on: November 20, 2016 - 02:20:13 PM »
What the '68 markers? Easy for fiberglass, you just need some fiberglass cloth and resin. Patch the original hole for the 72+ style markers and drill the correct sized hole for the '68 markers. Not sure if your fenders are painted already or not. If they're not you could put the '68 markers wherever you wanted. If they are, well, even putting the '68 markers where the 72 markers are now would require some touch up work around the marker.
