Author Topic: How to support front suspension during build-out on K member?  (Read 1030 times)
Offline dakota
« on: October 27, 2016 - 06:39:59 AM »
My engine and K-member are sitting on one of the high-tech piano mover carts from Harbor Freight.   I've mocked up one side of the front suspension as shown in the picture below.  With everything loose, the lower control arm droops down - no big surprise.   To keep from dinging up the dust shield by hitting the floor, will simply tightening the nut on the end of the lower control arm pivot shaft be enough to support the suspension including the front rotors during assembly?   I've got a small cardboard box tucked under the control arm for now, but knowing that the engine and suspension are going to be moved around the garage, this approach won't necessarily protect everything.  I'm guesssing/hoping there's enough resistance in the pivot shaft bushing to keep the components airborne but thought I would check with one of you that have already been done this road.
« Last Edit: October 27, 2016 - 06:43:18 AM by dakota »
Offline anlauto
Re: How to support front suspension during build-out on K member?
« Reply #1 on: October 27, 2016 - 06:59:49 AM »
Add your sway bar and your troubles will be forgotten  :2cents:
Offline 73_Cuda_4_Me
« Reply #2 on: October 27, 2016 - 09:44:36 AM »
I'd get a cheap ratchet strap, and put a bolt in the shock mount holes on lower CA, hook strap to that and loop over top of engine to other side, and tighten strap up to hold them up out of the way.
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
« Reply #3 on: October 27, 2016 - 09:51:07 AM »
Like Alan said, your sway bar will help hold up the control arms.  If they still hang too low, just modify your cart a little.  You can build a platform out of 2x4s that you can set on top of the cart that will move the K-member off the ground a little bit more.
Offline dakota
« Reply #4 on: October 27, 2016 - 10:18:47 PM »
Thanks for the suggestions, guys.
« Reply #5 on: October 28, 2016 - 12:31:12 AM »
A piece of mechanics wire tied from the top of the spindle to the K frame hole will work too
