Author Topic: Shock nut  (Read 1365 times)
Offline Cuda_451
Shock nut
« on: October 27, 2016 - 05:47:39 PM »
Has anybody had the top rear shock nut get stripped onto the bolt? Any idea on how to get it off?
1970 Plymouth Barracuda
1995 Dodge RAM 1500 SLT
2006 Ford Mustang V6 Supercharged
Re: Shock nut
« Reply #1 on: October 27, 2016 - 06:36:22 PM »
Not me thank goodnes... gonna be a SOB if so...  Strategy I've used successfully on occasion is to stick a flat blade screwdriver in between, in this case, the shock eyelet & the shock cross member to increase the tension so the nut can catch a thread.
You said bolt so I'm guessing your aware there needs to be a wrench on both ends to keep the bolt from spinning.  Tight quarters in the shock cross member area.. would be good to have an extra pair of hands to deal with....  :2cents:
Offline AARuFAST
  • AARuFAST
Re: Shock nut
« Reply #2 on: October 27, 2016 - 07:44:10 PM »
 :swear:  that sucks. why they didn't make covers in trunk to get to the top shock tower.
Hope your car is on a lift not laying on your back on floor,
jam a wrench on the bolt side and a long handle ratchet on nut to get loose.
you cannot leave ratchet on nut to remove it..
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline anlauto
Re: Shock nut
« Reply #3 on: October 27, 2016 - 08:05:54 PM »
torch time :villagers:
Re: Shock nut
« Reply #4 on: October 27, 2016 - 08:14:02 PM »
Torch it. Someone that knows what they're doing won't damage the crossmember.
Offline JH27N0B
Re: Shock nut
« Reply #5 on: October 27, 2016 - 08:33:13 PM »
I suppose the area is too tight to get a nut splitter on it?
Offline 1 Wild R/T
Re: Shock nut
« Reply #6 on: October 27, 2016 - 08:48:54 PM »
On a 70 the access hole is above the nut, so you can look straight down at it.... Which means you can torch it from above... Huge benefit as opposed to a 71... Good man with a torch should have no problem.... But I would suggest getting the fuel tank outta there just cause explosions are such a PITA.. Ya know dealing with the Cops, ATF, FBI, Homeland Security...
Offline anlauto
Re: Shock nut
« Reply #7 on: October 27, 2016 - 09:18:58 PM »
Maybe from the top if it's a 70
Offline Cuda_451
Re: Shock nut
« Reply #8 on: October 28, 2016 - 06:21:04 AM »
 Yeah, it's a 70. I'll probably just torch it this afternoon. This should turn out interesting. Haha
Offline Cuda_451
Re: Shock nut
« Reply #9 on: October 28, 2016 - 09:11:29 PM »
I cut the head off with a cut off wheel and just pulled the bolt through. I didn't trust myself with the torch lol
Offline blown motor
Re: Shock nut
« Reply #10 on: October 28, 2016 - 11:50:22 PM »
 :2thumbs:
Offline ebodycopper
Re: Shock nut
« Reply #11 on: October 31, 2016 - 04:33:27 PM »
I had the same thing happen to me.  My mechanic pounded on an undersized socket onto the nut.  The nut backed right out.
