Author Topic: Oil pressure  (Read 1074 times)
Offline Cuda_451
Oil pressure
« on: October 29, 2016 - 05:37:20 PM »
Oil pressure start out good and has slowly been dropping from 40 to 25 to 15 and now 5 but as motor Roma increase the oil pressure will be at 40 at close to 5k Roma. Any idea?
1970 Plymouth Barracuda
1995 Dodge RAM 1500 SLT
2006 Ford Mustang V6 Supercharged
Offline cudabob496
Re: Oil pressure
« Reply #1 on: October 29, 2016 - 10:18:17 PM »
what's Roma?
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
Re: Oil pressure
« Reply #2 on: October 29, 2016 - 10:30:47 PM »
Engine rpm, typo or some text autofill bs. Double check these readings first with a mechanical oil pressure gauge, it could be gauge error...
Offline Cuda_451
Re: Oil pressure
« Reply #3 on: October 29, 2016 - 10:39:31 PM »
I meant Rpms. And okay, I will. The gauge itself is pretty old so that maybe the problem.
Offline 734406pk
  • Andy
Re: Oil pressure
« Reply #4 on: October 30, 2016 - 12:28:47 AM »
 :thumbsup: Don't trust the factory dash gauge here for diagnostics, use a good mechanical gauge. Good Luck!
Re: Oil pressure
« Reply #5 on: October 30, 2016 - 01:58:14 PM »
Offline dougs bs23
Re: Oil pressure
« Reply #6 on: October 31, 2016 - 04:25:14 PM »
It's a city in Italy.  :bigsmile:
I thought it was a type of tomato
Offline moper
Re: Oil pressure
« Reply #7 on: November 02, 2016 - 08:37:32 PM »
You need 10psi per thousand rpm. I'm not sure if you're talking about idle oil pressure is 5 or what, but 5psi is low at idle, I like to have 15-20, and you need 50+ at 5K and if your engine revs higher you need more... If it was me I'd pull the engine and inspect.
