Author Topic: How to adjust accelerator pump shot?  (Read 1131 times)
Offline nsmall
« on: October 30, 2016 - 01:26:24 AM »
How to adjust accelerator pump shot?  My car has a hesitation with the new air gap intake.  Its a 340 engine, carter AFB carb.  Is the accelerator pump on the carb?  How do I increase the shot?
Obviously I dont know much about cars.  Try not to laugh to hard over this post.  It seems a little sad.  :)
Thanks,
Neil
Offline 1 Wild R/T
Re: How to adjust accelerator pump shot?
« Reply #1 on: October 30, 2016 - 02:06:26 AM »
This should help
Offline 1 Wild R/T
« Reply #2 on: October 30, 2016 - 02:09:43 AM »
And this article could help too....
http://www.thecarburetorshop.com/AFBtuningtips.htm
« Reply #3 on: October 30, 2016 - 08:25:44 PM »
If you have an instant stumble , which I believe was the case , then increasing the volume of fuel delivered is not going to help , it will just waste fuel , you need to get a bigger squirter so more fuel arrives instantly , unfortunatly they are only sold in Packs of 3 - small , what you already have & a larger one .
 raising the float level slightly can help though .
Offline 1 Wild R/T
« Reply #4 on: October 30, 2016 - 08:31:25 PM »
Or you can use a pin drill... But the another thing to look at is the check ball or needle under the squirter retaining screw...
Offline nsmall
« Reply #5 on: December 12, 2016 - 08:22:25 PM »
Chyrco Psycho, you were on the money.  Switched to squirter #43 vs the #28.  New problem, keeping tread on tires.
« Reply #6 on: December 12, 2016 - 08:24:52 PM »
I have seen that problem many times LOL  :burnout:
