Author Topic: Fuel Gauge and low fuel indicator issues  (Read 1271 times)
Offline miketyler
    • www.miketyler.net
« on: October 30, 2016 - 03:10:28 PM »
I have an issue that started some time back and has been bugging me ever since. My car is rally dash car with an Gran Coupe overhead console I added. Everything was added correctly, all OEM parts, overhead console, harness, etc and was working fine until one day I started it up and realized the low fuel indicator stays on and the fuel gauge reads about 1/4 tank too full. With full tank, the needle in the guage is buried to the right.
Because both issues occurred at the same time I am thinking they are related. Might this be faulty low fuel relay? All other guages seem to be functioning ok so I assume VR not part of it. Ideas on how to test and isolote the problem?
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline spamtank
Re: Fuel Gauge and low fuel indicator issues
« Reply #1 on: October 30, 2016 - 05:58:28 PM »
I have a similar (if not the same) issue with my 70 Challenger SE.
Also read a quarter tank when I ran out of gas once.
I've read that some have run a ground from the sending unit to the gauge (or mabe the LFE relay).
I've been meaning to try that.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline miketyler
    • www.miketyler.net
« Reply #2 on: October 31, 2016 - 09:14:12 AM »
Thanks for responding. I was hoping it wasn't the relay as they can be hard to find. I'll pull my dash out this week and check the ground. Also I'll dust off my manual and see if there's a procedure that might explain how to troubleshoot this condition.
72' Cuda restomod
70 Mustang Mach 1
Offline EB3-GranCoupe
  • BP23 U0B
« Reply #3 on: November 07, 2016 - 08:17:46 PM »
 :popcorn:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: November 08, 2016 - 04:36:15 PM »
You should take a resistance (ohm)reading at the sender and see what it says.
I think it's like between 9.5 ohms and 70 - 75 ohms. Empty to Full respectively.
