Author Topic: Water leak  (Read 747 times)
Offline money pit
Water leak
« on: October 30, 2016 - 09:41:05 PM »
On my 73 challenger the bottom radiator hose leaks at the lower outlet. I have a new radiator and new hoses. I tighten the hose clamp as tight as I could. I tried repositioning the clamp, I even tried new clamps. I had the same problem with the old radiator. Any suggestions? Thanks
Offline 1 Wild R/T
Re: Water leak
« Reply #1 on: October 30, 2016 - 11:18:16 PM »
Could be the water pump is leaking out the pee hole, typically the water runs down the hose & drips at the radiator area...
Offline mopar jack
Re: Water leak
« Reply #2 on: October 31, 2016 - 12:24:43 PM »
Had that problem before caused by the coiled spring in the hose. A piece of wire spring would get pinched between the hose and the outside of the rad fitting causing the leak.
Re: Water leak
« Reply #3 on: October 31, 2016 - 12:32:05 PM »
A little weatherstrip adhesive should seal the leak.  Worm style hose clamps can damage the hose if they are tightened too much.  Make sure you didn't damage the hose.
Offline money pit
Re: Water leak
« Reply #4 on: November 04, 2016 - 09:18:41 AM »
I did notice the pulleys have a rust stain. The hose I have on it doesn't have a spring. I'll try the weather strip glue. Thanks everyone for responding.
