Author Topic: 1971 cuda alignment specs. for polyglas E60-15  (Read 2157 times)
Offline culp71
« on: October 31, 2016 - 10:37:38 AM »
setting up suspension on a 71 340 cuda...looking for caster, camber and toe.
I know these numbers are susceptible to preference, but what is a good starting point/ AKA: factory stock, for alignment when using stock Goodyear polyglas E60-15 tires?
« Last Edit: October 31, 2016 - 02:04:41 PM by culp71 »
Re: 1971 cuda alignment specs. for polyglas E60-15
« Reply #1 on: October 31, 2016 - 03:27:07 PM »
I believe, with those tires, stock numbers are as good as you are going to get.
« Reply #2 on: November 01, 2016 - 09:45:06 AM »
x2.
If you change to radials, then you want to get more modern specs. Otherwise, stick with the OEM specs.
Offline smallhurst
« Reply #3 on: November 01, 2016 - 10:14:43 AM »
Stock numbers and stock tire pressures.  Are they new E60's?  Keep me in mind if you need some more!!
Offline culp71
« Reply #4 on: November 01, 2016 - 01:24:29 PM »
so what are the stock specs?
Offline culp71
« Reply #5 on: November 01, 2016 - 01:25:01 PM »
they are new Goodyear polyglas  E60-15's
Offline culp71
« Reply #6 on: November 09, 2016 - 08:57:03 AM »
I know these numbers are susceptible to preference, but what is a good starting point/ AKA: factory stock, for alignment when using stock new Goodyear polyglas E60-15 tires?
Offline 1 Wild R/T
« Reply #7 on: November 09, 2016 - 11:47:52 AM »
Stock
camber  0 to -.25
caster   +1
Toe   1/16th-1/8th
Even with the Polys I'd put more Caster into it....  Caster is a non-tire wearing angle so using more won't hurt anything but it will improve straight line stability & the return to center of the steering...
Camber is a tire wearing angle and the gains vs wear factor means keep it close to zero.. It you want to corner fast buy different tires...
Toe is a serious tire wearing angle & that spec doesn't change from granny's car through fairly hot corner carving... Race stuff will trade tire wear for quicker response...
Offline culp71
« Reply #8 on: November 09, 2016 - 02:09:28 PM »
thank you 1 Wild R/T!
