Author Topic: Well, here goes nothing.  (Read 10035 times)
Offline Rdchallenger12
« on: November 01, 2016 - 03:48:42 PM »
Okay all some of y'all have gotten familiar with me on here. For those that haven't I bought a triple green '73 Challenger at Mecum last year. The time has come for me to try my hand at my first resto, even though it's a small one, I'm going to need all the help I can get from y'all on here. On the list is.
340 swap
Get 904 tran rebuilt
New vinyl roof
Fix crack in dash
Repaint
Remove body side molding
Put on Rallye hood
Update some wiring and add a bloothooth amp in the rear.
I'm sure there will be more
« Last Edit: November 01, 2016 - 04:06:35 PM by Rdchallenger12 »
Re: Well, here goes nothing.
« Reply #1 on: November 01, 2016 - 03:50:18 PM »
So I bit the bullet and went for where the problem spot may be, original vinyl top. I had a leak coming in the trunk when washing the car so I expected the worst. Doesn't look to bad
« Reply #2 on: November 01, 2016 - 04:10:56 PM »
This is where the leak was coming from which lead me to biting the bullet on this resto.... common wisdom is the Dutchman panel but as you can see it's solid but does have surface rust, so I'm stumped as to where water was getting in at. Kind of thinking all I needed was a new weather strip around the trunk?!?!?!
Offline Mopar73340
« Reply #3 on: November 01, 2016 - 04:36:38 PM »
I had about the same size hole where the Dutchman panel and quarter were put together. Ended up with water in the trunk. I've also seen many with rust holes around the rear window under the stainless trim where water gets into trunk.
« Reply #4 on: November 01, 2016 - 04:41:04 PM »
There should be rubber seals around each clip that holds the vinyl top trim.  If that seal is dried out, you could have a leak through those trim holes.
« Reply #5 on: November 01, 2016 - 04:43:48 PM »
I thought it was a hole too but it's actually solid there, just a little indent
« Reply #6 on: November 01, 2016 - 04:46:29 PM »
Not a single one has anything around them   :dunno:
« Reply #7 on: November 01, 2016 - 04:52:57 PM »
Wait, or were you talking about underneath
« Reply #8 on: November 01, 2016 - 06:59:16 PM »
Not those pins...the clips that go through into the trunk. Your showing a hole for a trim clip right by your leak.
Offline IMNCARN82
  • LeDZeP
« Reply #9 on: November 01, 2016 - 07:04:25 PM »
there was water in the trunk when it was new! :poopoke:  Common. a hole in you're bucket eh!?  How much water were you gettn?
 Looks in good shape under there so far.
 :popcorn:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
« Reply #10 on: November 01, 2016 - 07:11:56 PM »
Ah, Yeah it pulled up when I pulled the trim. It was sealed lol that would've made to much sense on how I was getting water.
Wasn't much, just when I was washing it. Maybe a quarter cup if that.
« Reply #11 on: November 26, 2016 - 03:42:38 PM »
While doing the interior teardown today, I found this gem! Made my whole day!!!
Offline 73440
« Reply #12 on: November 26, 2016 - 03:56:07 PM »
Good deal, looks in great shape also!
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #13 on: November 26, 2016 - 05:13:22 PM »
That was under the rear seat.... I also found one under the drivers seat (it wasn't in such good of shape)
Offline blown motor
« Reply #14 on: November 27, 2016 - 09:50:16 AM »
The condition of that BS is amazing!
