Author Topic: Fuse Block Fuse Mount Rivets Arcing  (Read 900 times)
Offline 73_Cuda_4_Me
« on: November 03, 2016 - 10:32:41 AM »
Okay, was having an issue with turn signal not working periodically, and was checking fuse block for dirty contact on fuses, and noticed there was arcing going on under the fuse mount rivet that holds the fuse mount to the plastic block!
Anybody ran into this before?
What is the best way to correct it? Is there any way to tighten the rivet up or solder it to the fuse mount without messing up the fuse block?
 :swear:
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Re: Fuse Block Fuse Mount Rivets Arcing
« Reply #1 on: November 05, 2016 - 10:20:45 AM »
I doubt you could solder it without damage. It is possible to tighten up a rivet if you can get at both sides. Support the back side and using a flat tip punch and a hammer. Require removal from the car I would expect.
« Reply #2 on: November 08, 2016 - 08:30:00 AM »
 :cheers:
Thanks for this, dodj
R11 V6X EN2
