what is advantage of multi-port?
Better drive ability and more precise fuel delivery. This is still being used today in modern cars, but is being phased out by direct injection. We won't see direct injection as a retrofit, likely ever. Due to the injector needing to be within the cylinder, similar to a diesel.
Peak power between TBI and multi port will likely be the same, I suspect you will have better throttle response and perhaps more area under the curve with multi port.
Peak power and torque is cool if you are drag racing or holding that rpm a high percentage of the time. But it's not the only thing that makes a good street car.
