Author Topic: A/C Line Question  (Read 1108 times)
Offline jmartin99
A/C Line Question
« on: November 08, 2016 - 09:23:54 PM »
I am putting together a '72 Challenger for a friend and I have all of the original A/C lines but the aluminum lines are very dirty. What is the best way to make them look good again? Media blast? Steel wool?  :dunno:
Thanks!
Jeff  :cheers:
Offline anlauto
Re: A/C Line Question
« Reply #1 on: November 08, 2016 - 09:30:03 PM »
Depends on the level of restoration....You can wire wheel them, or media blast and paint the silver and black or you can send them out to be re-plated...
Offline jmartin99
« Reply #2 on: November 08, 2016 - 09:34:39 PM »
If I media blast, what type of media would you recommend using?
Thanks!
Jeff
Offline twalker
« Reply #3 on: November 08, 2016 - 09:40:06 PM »
Steel wool / SOS pad
Sent from my iPad using Tapatalk
Offline twalker
« Reply #4 on: November 08, 2016 - 09:40:51 PM »
If there is a lot of paint on them, brake fluid
Offline anlauto
« Reply #5 on: November 08, 2016 - 09:44:29 PM »
 :dunno: glass bead....make sure to cap them off and really clean them out afterwards :2cents:
Offline reborn73
« Reply #6 on: November 08, 2016 - 09:46:29 PM »
I wire wheeled mine.  You can see two of them in this pic.  They were in pretty good shape to start with though
Offline jmartin99
« Reply #7 on: November 12, 2016 - 12:35:54 AM »
Reborn73,
   Could you possibly post a pic or two of the two A/C lines that attach to the condenser? I believe I have the correct lines but when I attempt to connect them to the fittings on the compressor they do not seem to fit as easy as they should.
   Thanks!
Jeff   :cheers:
